check light after seafoam!!
Old Nov 20, 2004 | 02:23 PM
stock_cx's Avatar
Default check light after seafoam!!
i just just seafoam my car and ofter 15 min i turn on my engine and i have a check engine light, (pour into brake line). what kind of harm can it do to my newly purchase db8. i have used seafoam lots and lots of times on other cars with great success. On my gsr i didn't even used that much, almost 1/3. hope my car is okay, just reseted my ecu lets see what happens. should i go ahead and put seafoam in the tank?
Old Nov 20, 2004 | 02:27 PM
Jeff_B's Avatar
Default Re: check light after seafoam!! (stock_cx)
You might need to replace your spark plugs and o2 sensor after using SeaFoam...
W.O.P.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_cx &raquo;</TD></TR><TR><TD CLASS="quote"> i just just seafoam my car and ofter 15 min i turn on my engine and i have a check engine light, (pour into brake line). what kind of harm can it do to my newly purchase db8. i have used seafoam lots and lots of times on other cars with great success. On my gsr i didn't even used that much, almost 1/3. hope my car is okay, just reseted my ecu lets see what happens. should i go ahead and put seafoam in the tank?</TD></TR></TABLE> sounds weird never happened to me when i seafoamed my car. but i wouldnt put the rest in until you can run a diagnostic on your car to find out what code your throwing first
Old Nov 20, 2004 | 02:29 PM
W.O.P.'s Avatar
Default Re: check light after seafoam!! (ChassisInnovations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChassisInnovations &raquo;</TD></TR><TR><TD CLASS="quote">You might need to replace your spark plugs and o2 sensor after using SeaFoam...</TD></TR></TABLE> but i wouldnt jump to that yet. like i said i would test it first
Old Nov 20, 2004 | 02:30 PM
stock_cx's Avatar
Default Re: check light after seafoam!! (chirpin_3rd)
it never had happen to me before either. my buddy has my odb11 scanner and he's at work; i haven't seen that scanner in almost two years.
Old Nov 20, 2004 | 02:35 PM
W.O.P.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_cx &raquo;</TD></TR><TR><TD CLASS="quote">it never had happen to me before either. my buddy has my odb11 scanner and he's at work; i haven't seen that scanner in almost two years. </TD></TR></TABLE> wow an obd11 scanner? performance mods must be a bitch on his car! lol j/k but well say OBD2
Old Nov 20, 2004 | 02:39 PM
..::91TEG-G2::..'s Avatar
sometimes seafoam can cause more harm then good in some cases. you're engine might of been working properly because it clauging up the little crevestes that was keeping your compression right. and now that it cleaned all that out.. you could start to have problems.
did you check to see if it threw any codes? if so, what were they
Old Nov 20, 2004 | 07:00 PM
stock_cx's Avatar
Default Re: check light after seafoam!! (..::91TEG-G2::..)
couldn't called my buddy for my code scanner so i just reset ecu, code went away. i'm still thinking what it was though.
Old Nov 21, 2004 | 05:23 PM
jdmkrazie's Avatar
it could just be a misfire in one of the cylinder which most likely i'm sure it is... if after resetting the ecu and it staying off then it probably was.
clsmooth135
Jun 3, 2007 05:16 PM
walsh22
Jan 7, 2007 07:34 PM
KetteringITR
Nov 15, 2004 10:03 AM
B16CRXT
May 1, 2004 02:32 PM
Defiant1999
Jun 3, 2003 10:41 AM
