Front side panel
Old Nov 20, 2004 | 02:20 PM
pmelapp12's Avatar
Default Front side panel
Six months or so ago my wife wrecked my 99 accord. Totally jacked up the front end, everything around the engine was cocked to the right.(frame I mean) I noticed the other day that the front right panel isn't lined up correctly. Is that something I can fix by loosening bolts and adjusting or does it need to go to a body shop. I've noticed other stuff like the right front door closing fine but the top corner sticks out a little and the hood is a little off. Guess I should have looked at this stuff a little harder 6 months ago when the body work was under warranty. Another lesson learned. thanks for any help.
Old Nov 20, 2004 | 02:53 PM
eauto's Avatar
Default Re: Front side panel (pmelapp12)
Take it to the shop. I had similar problem and I let it slide. What will happen is, slowly as you drive and brake, the panel will shift back and one day, when you leat expect it, you open the card dooor, it will hook into the panel and you will bent the panel.
hTH
Old Nov 20, 2004 | 03:45 PM
Riceburner247's Avatar
Default Re: Front side panel (eauto)
Well, if your frame is bent, you need to have a shop straighten it. Nothing will line up correctly until you do this.
GoLowDrew
Paint and Body
15
Nov 22, 2015 04:18 PM
lilmine_1
Jan 16, 2011 06:50 PM
Lazydsm
Welding / Fabrication
Apr 12, 2005 06:08 PM
4drEF
13
Jan 13, 2004 08:18 AM
