need some help with my R6.. idle issues!!
Old Nov 20, 2004 | 01:58 PM
typeeg's Avatar
Default need some help with my R6.. idle issues!!
Well my R6 is acting a lil wierd lately. When riding there are no problems but when the bike is fully warmed up and idling, the idle jumps up and down a lil bit.. it sits at around 1.4k rpm and hops up and down to around 1.7krpm back and forth. Any ideas on what the problem may be? It's a 2003 btw.
Old Nov 20, 2004 | 02:26 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: need some help with my R6.. idle issues!! (R6)
How many miles do you have and when was your last oil change?
Old Nov 21, 2004 | 11:37 AM
typeeg's Avatar
Default Re: need some help with my R6.. idle issues!! (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">How many miles do you have and when was your last oil change?</TD></TR></TABLE>
about 3200 and oil change about 2k miles ago.
Old Nov 22, 2004 | 02:54 PM
typeeg's Avatar
No one wants to help out?
It has a D&D slip on and I don't think the previous owner did a power commander on it. Could this be an issue?
Old Nov 22, 2004 | 04:43 PM
.Ash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6 &raquo;</TD></TR><TR><TD CLASS="quote">No one wants to help out?
It has a D&D slip on and I don't think the previous owner did a power commander on it. Could this be an issue?</TD></TR></TABLE>
your exhaust should not be an issue. i've been running my bike on a full exhaust, no PC; it runs fine. at worst i am running with less power than i could be.
Old Nov 22, 2004 | 04:53 PM
ScareyH22A's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6 &raquo;</TD></TR><TR><TD CLASS="quote">when the bike is fully warmed up and idling, the idle jumps up and down a lil bit.. it sits at around 1.4k rpm and hops up and down to around 1.7krpm back and forth.</TD></TR></TABLE>
Like how is it idling? In more detail.
Old Nov 22, 2004 | 05:06 PM
D2N's Avatar
D2N
Bump the idle u[ some with the adjuster until it idles evenly.
If it won't idle evenly then it sounds like the throttle bodies need to be synchronized.
Old Nov 23, 2004 | 11:28 AM
typeeg's Avatar
Like how is it idling? In more detail.</TD></TR></TABLE>
When the bike is warmming up it idles fine. Once it is fully warmed up the idle starts to bounce... I'd say a good 300rpms up and down up and down. While riding it doesn't have this problem at all. You sure it isn't the exhaust? I've heard from many that if you dont retune your bike after a mod that this could happen.
Old Nov 23, 2004 | 11:55 AM
rastropovitch
Guest
Posts: n/a
Oil change? Jeeze
Old Nov 23, 2004 | 12:44 PM
typeeg's Avatar
Default Re: need some help with my R6.. idle issues!! (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">Oil change? Jeeze</TD></TR></TABLE>
Oil change has been done recently.
Old Nov 23, 2004 | 02:20 PM
ScareyH22A's Avatar
Community Builder
Oil change has been done recently.</TD></TR></TABLE>
This thread's been bother'n me since the day it was posted so just right now, I went out to my bike, warmed it up, and this is what I saw.
My needle jumps around from 1100-1300 rpms. My last oil change was about 1500 miles ago. And its a 2004 R6.
If you feel that you're bike is idling out of spec, take it to the dealer and have them confirm it.
Here are some factors pertaining to "Incorrect Engine Idling Speed" according to my Yamaha Service Manual.
Incorrect valve clearance
Damaged valve train components
Clogged air filter element
Damaged or loose throttle body joint
Improperly synchronized throttle bodies
Improperly adjusted engine idling speed (throttle stop screw)
Improper throttle cable free play
Flooded throttle body
Faulty air induction system
Discharged battery
Faulty battery
Incorrect spark plug gap
Incorrect spark plug heat range
Fouled spark plug
Worn or damaged electrode
Worn or damaged insulator
Broken or shorted primary or secondary coils
Cracked or broken ignition coil
Faulty ECU
Faulty crankshaft position sensor
Faulty cylinder identification sensor
Don't guess... use that warranty.
Old Nov 23, 2004 | 02:38 PM
typeeg's Avatar
Discharged battery
Faulty battery
Fouled spark plug
Faulty ECU
is that all???
lol.. no warrenty bro.. guess I'm going to have to start checkin those things..
b20acura
Jan 24, 2007 12:43 PM
blurrrcivic94
Sep 7, 2005 08:16 AM
kihun_cha
Honda Motorcycles
Jul 30, 2005 04:00 PM
ProjectF4
Honda Motorcycles
Sep 29, 2004 08:54 PM
TypeRPaul
May 21, 2004 05:43 PM
