gauge swap
You can make anything fit with modifaction. It will not directly fit. You will have to do some custom wiring. I would just get a JDM Cluster or a Si/EX Cluster. It will be less of a headache.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">wow that seems pretty hard. i dont think it can be done!!!11</TD></TR></TABLE>
lmfao
really though, it's quite a bit of work but there's plenty of people who have done it on here that've done writeups. like the other guy said, just buy a JDM cluster (especially cuz we all know JDM 0wns 4LL
) that'd be a direct fit without any rewiring hastles.
lmfao
Ok, In the civic to get to your gauges take off the top 2 screws above your cluster then pop off the hazzards and the clock there is two screws behind that take those off then pull off the black bezel piece, now there are 4 screws that actually hold the cluster in...Now to get the LS cluster to work this is how I did it, take off the plastic piece and just cut the top piece off it till it will fit in the civic with the bezel in place, on mine I just dont have the plastic cover on at all. Most people say you cant just screw it in but mine literally just screwed right in and it lined up perfect, the top doesnt look that great it just looks like there's vents there its not bad at all. You arent done yet cause the plugs dont work in a civic you have to splice the wires with an integra plug using this guys diagram. https://honda-tech.com/zerothread?id=1053318 I have integra plugs if you need them $25 shipped and they are yours. Hope this helps you out
dood i never tell anybody this but this topic has been covered a gang of times
use the search and type in cluster or gsr cluster and what you looking for shuld come up
but yes anything can fit . but it takes patience
