new brake pads smoking?
Just put new generic pads on my cibic (it has an R sticker on it so Im posting in here) and they are smoking like a ****. is this a normal thing sometimes? it smells like burning and im just waiting for sparks to start flying.
its definitely sticking...at first i thought the ebrake was sticking but thats not it. it feels like the pads are constantly rubbing. i put in new rotors as well but didnt do anything out of the ordinary.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">did you clean and grease the slide pins?</TD></TR></TABLE>
nope, never usually do that
rob, i hardly used them. when i pull out of my driveway, which is on a slight incline, the car doesnt roll when in neutral with no brakes applied lol
what do you guys think about this as a possible problem...
the fluid was low while the old rotors and pads were on there. i added fluid recently before changing to the new pads and rotors. you think i could have too much brake fluid in there (brake pressure?) and its not allowing the calipers to open fully?
checked the fluid, it was ready to pour out of the reservior. took out some, went for another drive. seemed to feel a bit better, so i beat on the brakes pretty good. i could still smell it burning inside the car. got back to my house, sure enough the brakes were smoking, and rotors were glowing lol. nascar style baby
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paRRRker »</TD></TR><TR><TD CLASS="quote">if u grease everything up and it still sticks...adjust the wing nut on the brake boosta </TD></TR></TABLE>
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">you should be using some high temperature grease</TD></TR></TABLE>
use SILICONE grease. i can't stress this enough. standard wheelbearing grease will make the pins/shims stick. 3m makes the best stuff, but any silicone grease will do. also, put it on/behind the brake pad clips. this will give the pads a smooth ride.
BrakeExpert
Suspension & Brakes
Apr 9, 2012 05:59 PM
BrakeExpert
Suspension & Brakes
Sep 13, 2008 09:11 AM
Archidictus
Suspension & Brakes
54
Aug 12, 2005 09:54 PM
