ITR swap 96-97 or 98 up?
Old Nov 20, 2004 | 10:03 AM
colinproctor's Avatar
Default ITR swap 96-97 or 98 up?
i am looking to know how to tell the difference in a 96-97 ITR swap and a 98 up swap. what are the things that i could look for that would tell me that it was either years? i already know the header, but other than that. is there any knid of stamp on it or marking that would determine the year. thanks for any help.
Old Nov 20, 2004 | 10:06 AM
B2FiNiTY's Avatar
Default Re: ITR swap 96-97 or 98 up? (FdOoUoRr)
I'm assuming you are talking about JDM B18C (R) swaps.
The 98 up have a 4-1 one peice header but often that can be changed out. Noticably the transmission has a higher final drive along with a longer 4th and 5th gear.
Old Nov 20, 2004 | 10:36 AM
Default Re: ITR swap 96-97 or 98 up? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming you are talking about JDM B18C (R) swaps.</TD></TR></TABLE>
yes, as i stated ITR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">The 98 up have a 4-1 one piece header but often that can be changed out. Noticeably the transmission has a higher final drive along with a longer 4th and 5th gear.</TD></TR></TABLE>
i know these things, thanks. but other than actually looking at the 4-1 header, there is no other way to tell? there is no way to determine from the outside of the tranny which one it is, 4.4 or 4.7 final drive? i need to be able to look at something on the outside of the motor, other than the header, and determine what year and tranny it is.
Old Nov 20, 2004 | 10:53 AM
B2FiNiTY's Avatar
The only thing you can hope for is that the tranny still has its stamp because those usually wash off.
You can also check the year of the head. That will usually tell you assuming that someone isn't trying to pull a fast one.
Old Nov 20, 2004 | 02:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">The only thing you can hope for is that the tranny still has its stamp because those usually wash off.</TD></TR></TABLE>
the tranny does have the J4D LSD stamp on it. but that still doesnt specify whether or not it is the 4.4 or 4.7 final drive tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">You can also check the year of the head. That will usually tell you assuming that someone isn't trying to pull a fast one.</TD></TR></TABLE>
how do i go about checking the year of the head?
Old Nov 20, 2004 | 02:59 PM
daddy ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr &raquo;</TD></TR><TR><TD CLASS="quote">what are the things that i could look for that would tell me that it was either years?.</TD></TR></TABLE>
Is there a Vin# on the engine or an engine block# stamped like on the UD models ?
http://cgi.ebay.com/ebaymotors...sting
If you go to the link above you'll see a typical engine block stamp for a 2001 type R ..... I know the JDM engines have this type of stamp also
Modified by daddy ITR at 2:28 AM 11/21/2004
Old Nov 20, 2004 | 03:30 PM
Default Re: ITR swap 96-97 or 98 up? (daddy ITR)
JDM motors have no VIN #'s.
it does have the block code stamped on the block under the B18C. i dont know how to identify the year with that though.
Old Nov 20, 2004 | 03:38 PM
jmk2888's Avatar
Just above the header or exhaust manifold there is a stamp on the block looks like a round clock, there is a stamp that indicate the year.
Should like 9/6 that means it's a 1996 or 0/1 meaning 2001.
Modified by jmk2888 at 1:00 AM 11/21/2004
Old Nov 20, 2004 | 04:01 PM
808dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr &raquo;</TD></TR><TR><TD CLASS="quote">the tranny does have the J4D LSD stamp on it. but that still doesnt specify whether or not it is the 4.4 or 4.7 final drive tranny.</TD></TR></TABLE>
Yes it does.
J4D = 4.4 ITR final drive (JDM 96 spec/USDM all)
N3E = 4.7 ITR final drive (JDM 98 spec)
Old Nov 21, 2004 | 08:29 AM
Default Re: ITR swap 96-97 or 98 up? (808dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808dc2 &raquo;</TD></TR><TR><TD CLASS="quote">J4D = 4.4 ITR final drive (JDM 96 spec/USDM all)
N3E = 4.7 ITR final drive (JDM 98 spec)</TD></TR></TABLE>
i have never heard this. can anyone back this up?
Old Nov 21, 2004 | 09:48 AM
1999all_motoR_teg's Avatar
He is right. If the stamp says J4D LSD then it's a 96-97 JDM or USDM tranny with the 4.4 final drive.
The 4.785 final drive trannies have the stamp N3E LSD
Old Nov 21, 2004 | 01:02 PM
Default Re: ITR swap 96-97 or 98 up? (1999all_motoR_teg)
anybody else know anything?
thanks for all the info.
Old Nov 21, 2004 | 07:44 PM
there is a 9/? on the block. the 9 is there but the number on the other side of the 9 is not there. perhaps grinded off maybe. so its anywhere from a 96 to a 99. so i guess the tranny stamp gives it away?
Old Nov 21, 2004 | 07:53 PM
lakerschamp2000's Avatar
to identify the block whether it is 96-97 or 98+ you would need to check the 7digit number located right under b18c.
for example:
if it start at 1903433, then it from 96-97
if it start from 2034234, then it is 98 up spec.
basically, the first 2 numbers are to determine the year made.
Old Nov 21, 2004 | 08:19 PM
1Quikgsr's Avatar
The 98 up have a 4-1 one peice header but often that can be changed out. Noticably the transmission has a higher final drive along with a longer 4th and 5th gear. </TD></TR></TABLE>
Old Nov 21, 2004 | 08:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr &raquo;</TD></TR><TR><TD CLASS="quote">there is a 9/? on the block. the 9 is there but the number on the other side of the 9 is not there. perhaps grinded off maybe. so its anywhere from a 96 to a 99. so i guess the tranny stamp gives it away?</TD></TR></TABLE>
Yes the tranny stamp gives it away. If the person selling it tried to pass it off as a newer motor for more money and grinded off the number(cause it should be there) then they obviously didn't know about the stamp on the tranny.
Old Nov 21, 2004 | 09:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg &raquo;</TD></TR><TR><TD CLASS="quote">Yes the tranny stamp gives it away. If the person selling it tried to pass it off as a newer motor for more money and grinded off the number(cause it should be there) then they obviously didn't know about the stamp on the tranny.</TD></TR></TABLE>
wow, well that sucks. i got a 96-97 for a 98 up price, awsome.
Old Nov 22, 2004 | 05:53 AM
EVILhatch's Avatar
96-97 blocks have red paint on the b18c stamp
Old Nov 23, 2004 | 11:26 AM
Default Re: (EVILhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVILhatch &raquo;</TD></TR><TR><TD CLASS="quote">96-97 blocks have red paint on the b18c stamp</TD></TR></TABLE>
and as you can see mine has a red stamp
disappointed
Old Nov 23, 2004 | 11:40 AM
B2FiNiTY's Avatar
Default Re: (FdOoUoRr)
red/orange paint is oem replacement block.
Old Nov 23, 2004 | 11:45 AM
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">red/orange paint is oem replacement block. </TD></TR></TABLE>
so whats that mean? its been messed up?
Old Nov 23, 2004 | 11:51 AM
jmk2888's Avatar
so whats that mean? its been messed up?</TD></TR></TABLE>
It means that someone purchased another block from Honda, because the first or original block was messed up.
You should be o.k.
Have you installed it yet?
Old Nov 23, 2004 | 11:54 AM
Default Re: (jmk2888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 &raquo;</TD></TR><TR><TD CLASS="quote">It means that someone purchased another block from Honda, because the first or original block was messed up.
You should be o.k.
Have you installed it yet?</TD></TR></TABLE>
no i havent installed it yet.
i was told that i was getting a 00' swap with 12k on it. so i am not happy with a 96-97 while i paid to get a 98 up and it has enough miles on it to have had a cracked block or something that the block needed replacement.
Old Nov 23, 2004 | 11:58 AM
splitime's Avatar
Who did you purchase this block/swap through?
Old Nov 23, 2004 | 12:11 PM
JinDIESEL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg &raquo;</TD></TR><TR><TD CLASS="quote">He is right. If the stamp says J4D LSD then it's a 96-97 JDM or USDM tranny with the 4.4 final drive.
The 4.785 final drive trannies have the stamp N3E LSD</TD></TR></TABLE>
i dont think he's fully right on this one. i have a 97 jdm itr engine. my transmission DOES NOT come with the J4D LSD stamp on it. accordin to the guys down at hmotorsonline.com, only the 98+ JDM ITR's come with this stamp. that's because the final drive for the 96-97 is 4.4 and the 98+ is 4.7 ... maybe the N3E is the 01+ jdm itr spec?
