Rear Wiper
Old Dec 28, 2001 | 06:01 AM
Random.Hero's Avatar
Default Rear Wiper
Does anyone know where I could get instructions on how to remove the rear wiper? Also, does anyone have the part number for the plug and how much? Thanks!
Old Dec 28, 2001 | 06:05 AM
Back in Black's Avatar
Rather OG
Default Re: Rear Wiper (YellowITR01)
http://www.sandmracing.com/rearwiperremoval.html
Old Dec 28, 2001 | 06:06 AM
Willard's Avatar
Default Re: Rear Wiper (Darth VadeR)
Daymit... you beat me to it.
Will
Old Dec 28, 2001 | 06:26 AM
Jason's Avatar
these are the part #'s for the plug, washer, grommet, and bolt...
90301-SR3-000
90156-SH3-000
94103-14200
76707-ST7-000
but I don't know which is which...take em all to honda
Old Dec 28, 2001 | 06:27 AM
Mike K's Avatar
Default Re: Rear Wiper (typer98)
Plug
90301-SR3-000
Grommet
76707-ST7-000
Bolt
90156-SH3-000
Washer
94103-14200
Old Dec 28, 2001 | 06:46 AM
White Dragon's Avatar
Default Re: Rear Wiper (Mike K)
Plug
90301-SR3-000
Grommet
76707-ST7-000
Bolt
90156-SH3-000
Washer
94103-14200
Really, the only thing you need is the plug and the washer. That's all I used. Am I missing something?
Old Dec 28, 2001 | 08:35 AM
Cosworth's Avatar
Default Re: Rear Wiper (White Dragon)
WD - you only need the plug & a washer as you re-use the grommet and the nut.
Old Dec 28, 2001 | 08:48 AM
Default Re: Rear Wiper (Cosworth)
Thanks for confirming Cosworth
Old Dec 28, 2001 | 10:26 AM
Jason's Avatar
that's correct, but when I got the kit from Mike K. he included everything, so just figured I'd pass on all of the info
Old Dec 28, 2001 | 10:30 AM
Rdriver's Avatar
How much weight will this remove????
Old Dec 28, 2001 | 01:12 PM
BoM's Avatar
BoM
Default Re: Rear Wiper (Rdriver)
if the wiper motor is the same as the antenna one its like 3-4 lbs
Old Dec 28, 2001 | 05:19 PM
project_DC2's Avatar
20 lbs, thats what you call weight reduction! hahah...
Old Dec 28, 2001 | 05:52 PM
Todatyper's Avatar
Default Re: Rear Wiper (project_DC2)
I liked how they smoothed out the JDM header welds. They wrote that they needed to spend $85 on welding. What did they need to weld? I thought they just sand down the stock welds.
Old Dec 28, 2001 | 06:55 PM
MattGSR's Avatar
how much is the plug and washer shipped to 94538 CA? thanks
Old Dec 28, 2001 | 07:15 PM
Padawan's Avatar
Darth ModerVader
Default Re: Rear Wiper (Todatyper)
The flange needs to be welded to the primaries from the outside before the inner welds can be ground down. It should be bolted to a jig to prevent warping from the heat of the welding as well.
Old Dec 28, 2001 | 07:18 PM
GQ 05YellowEVO8's Avatar
Default Re: Rear Wiper (SpecR0123)
Check this out homemade from Home Depot
[Modified by VTEC-MAN95GSR, 11:20 PM 12/28/2001]
[Modified by VTEC-MAN95GSR, 11:21 PM 12/28/2001]
Old Dec 28, 2001 | 07:25 PM
01CWITR's Avatar
Default Re: Rear Wiper (VTEC-MAN95GSR)
Old Dec 28, 2001 | 07:56 PM
jetydosa's Avatar
25 Year Member
Default Re: Rear Wiper (A032R)
How much for the "kit"?
CantKnckDaHustle
Mar 25, 2005 12:14 PM
dVeLoPe
Sep 4, 2004 05:46 PM
Dirt
Jun 21, 2002 05:55 PM
Integra_B18B
May 23, 2002 05:50 AM
