Coolant Line Turbo Pics
Old Nov 20, 2004 | 08:46 AM
calvinPGMFI's Avatar
Default Coolant Line Turbo Pics
well i always block the coolant lines on the turbo off.
On my new setup i thought, it couldn't hurt if i connected them.
I have disgined the coolant lines with a fellow HT member(netherlands).
What do think of it?
My downpipe 3" inch
See my website for my complete setup and setup pics. http://www.cjperformance.com
Old Nov 20, 2004 | 08:58 AM
krazn's Avatar
Default Re: Coolant Line Turbo Pics (calvinPGMFI)
i dont know the answer, but it sure as hell looks sweet.
Old Nov 20, 2004 | 09:00 AM
m R g S r's Avatar
How are you connecting them to the waterpipe?
Old Nov 20, 2004 | 10:12 AM
Default Re: Coolant Line Turbo Pics (m R g S r)
I'm connecting them do the stock heat exchanger(oil filter)
Old Nov 20, 2004 | 10:48 AM
importboi22's Avatar
looks hell alot better than 10 feet of braided lines!!!!
Old Nov 20, 2004 | 12:47 PM
hondaguyef's Avatar
Default Re: Coolant Line Turbo Pics (krazn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazn &raquo;</TD></TR><TR><TD CLASS="quote">I don't know the answer, but it sure as hell looks sweet. </TD></TR></TABLE>
Old Nov 20, 2004 | 01:28 PM
Tony the Tiger's Avatar
Hard tubing coolant lines = Very good idea especially when the lines are close to exhaust/turbo components
Old Nov 20, 2004 | 01:39 PM
B18C1CYA's Avatar
looks nice , thats a good idea i think
Old Nov 20, 2004 | 01:50 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinPGMFI &raquo;</TD></TR><TR><TD CLASS="quote">I'm connecting them do the stock heat exchanger(oil filter)</TD></TR></TABLE>
can u post finished pics..when that time comes please..
Old Nov 20, 2004 | 02:17 PM
BoostedJeff's Avatar
Default Re: Coolant Line Turbo Pics (bruceleeroy)
noice
Old Nov 20, 2004 | 02:23 PM
Default Re: Coolant Line Turbo Pics (BoostedJeff)
thanks.
do you maybe know the npt thread on the turbo coolant inlet/outlet? so i can order the right connector from summit. the pipe OD is 15mm i think that a 10-an hose must fit(with an eco-clamp).
CJ
Old Nov 21, 2004 | 12:16 AM
bump for the npt
Old Nov 21, 2004 | 12:38 AM
Mag00n's Avatar
Looks good man but a waste of time and effort in my OPINION. A turbo timer would be just as effective.
Old Nov 21, 2004 | 04:28 AM
Default Re: Coolant Line Turbo Pics (Mag00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n &raquo;</TD></TR><TR><TD CLASS="quote">Looks good man but a waste of time and effort in my OPINION. A turbo timer would be just as effective.</TD></TR></TABLE>
Turbo timer is great, but it will never be better than a watercooled turbo. The turbo timer will only prevent oil from coking.
Just from the fact that the turbo will always run cooler with the coolant flowing though the turbo is a good enough reason to run water lines. Oil temps will also stay lower.
I have another turbo car that does not have coolant lines (a T66)... After the car did a dyno pull, the compressor housing is hot enough to give you some serious burns.
On my Integra with a watercooled turbo, I could actually lay my hand on the compressor housing for a sec right after a dyno pull. That is how much cooler the turbo runs.
It's definitely worth the effort
Old Nov 21, 2004 | 08:40 AM
Bailhatch's Avatar
Default Re: Coolant Line Turbo Pics (Tony the Tiger)
That is the cleanest/best way I have seen yet. good job. I plan on doing a similar routing for my oil feed. There is no reason to have a stainless line draped around the motor IMO.
Old Nov 21, 2004 | 10:35 AM
vtec69's Avatar
someone looks happy to be in this pic
Old Nov 21, 2004 | 10:58 AM
mrDFWmechanic's Avatar
are thoes 2 brackets on the bottom of the motor meant to hold the downpipe ?? i've never seen somebody do that before
Old Nov 21, 2004 | 11:11 AM
blackANESE's Avatar
Default Re: (iROCKtheSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">are thoes 2 brackets on the bottom of the motor meant to hold the downpipe ?? i've never seen somebody do that before</TD></TR></TABLE>
They are the tranny brackets
Old Nov 21, 2004 | 11:43 AM
turboteg96's Avatar
Default Re: (blackANESE)
Are you going to run fittings and braided lines on the turbo. I am currently running rubber hoses and the amount of problems it has given me is ridiculous. I would so like to run steel 5/8's or 1/2 piping directly from the turbo and then connect rubber say about a foot or so back. Just to keep the rubber from always melting or the hose clamps from allways comming loose. ARgh!!!
Old Nov 21, 2004 | 12:30 PM
Mad Cow's Avatar
What did you use to bend the pipes? Are they aluminum?
Old Nov 21, 2004 | 03:39 PM
blue2ksi's Avatar
holy crap look at that turbo
Old Nov 22, 2004 | 04:25 AM
Default Re: (blue2ksi)
i wanted to run SS braided lines and russel connectors to the metal pipes
Old Nov 22, 2004 | 12:46 PM
gaskleppie's Avatar
The pipes are made from iron with galvinised coating. (spelling right?)
I just bent it with a pipe-bending-tool, nothing special...........
Old Nov 22, 2004 | 01:06 PM
RACEPAK's Avatar
dude is that your house?
great method.. never crossed my mind.
keep up the good work...
Old Nov 22, 2004 | 01:17 PM
blundar's Avatar
looking good calvin...
The water inlet+outlet on my t3 + t3/t4 both had some kind of flange held to the turbo with two bolts - I just cut a piece of 1/4" plate steel with the plasma cutter to be vaguely the right shape, welded a section of pipe to it, pressed it flat again and then cleaned it up in the grinder. Worked well enough, but probably not quite as elegant as what you're looking for.
