tranny problems please help!!!!!
I just started drviing my car again after two months of it not being driven because i was in a car accident. ne ways I was driving the car and i started to notice that its starting to get hard to put into first gear everytime I stop. Then eventually it wouldnt go in at all. So i started to take off in second gear and the same thing started to happen also. eventually i couldtn get it int o any gear at all. I would have to play with the shifter to get into gear and that would work only sometimes. the other time if i was stop i would have to turn the car off and put it into first. and i would also notice while i was in first with the clutch pedal pushed all the way down my car would just start creeping up by itself. I also cant down shift at all, and the tranny would make a squeaky sound when i tap the clutch pedal a little bit but then go away when the clutch pedal is all the way down. also i installed a excedy racing organic clutch in feb with a fidanza flywheel. please i need ur suggestions. also i bleed the line and that only made the shifting work for a little bit.
thanks guys
thanks guys
would that be covered undr warranty cause i still have that and i thought i would be my pressure plate or my throw out bearing thats just what i thought
Check behind your clutch pedal against the inner firewall. See if there is any fluid leaking out. If there is, it's the clutch MC. If there isn't, it's possible that there's something going on with your clutch, but you need to check the MC first.
btw, what car do you have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp »</TD></TR><TR><TD CLASS="quote">Check behind your clutch pedal against the inner firewall. See if there is any fluid leaking out. If there is, it's the clutch MC. If there isn't, it's possible that there's something going on with your clutch, but you need to check the MC first.
btw, what car do you have?</TD></TR></TABLE>
like he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsx veilside »</TD></TR><TR><TD CLASS="quote">would that be covered undr warranty cause i still have that and i thought i would be my pressure plate or my throw out bearing thats just what i thought </TD></TR></TABLE>
If your warranty is still good then go have the dealer check it out
Who installed the clutch? I know I had some dumb shop called HappydoRacing do my clutch and messed it up, I had to tow it to my house and do it myself, As they installed the clutch disk backwards. Maybe your Throw out bearing is bad and causing the problems. If the MC or SC were bad the fluid leval would be down from normal so check that out.
mon im going to have my friend take it apart and see whats wrong i would do it myself but my leg is still not fully recovered from the accidnet i was in
BlackOutIntegra
May 6, 2004 10:47 AM
