AEM Tru-time cam gears
Old Nov 20, 2004 | 03:09 AM
JFG Kevin's Avatar
Default AEM Tru-time cam gears
I been hearing rumors that those cam gears slip on you...is this true?
Old Nov 20, 2004 | 03:11 AM
2k.civic.si's Avatar
Default Re: AEM Tru-time cam gears (aznstyler119)
nope....i run them...if they sliped im sure i woulda noticed one of the times i shifted at 9,800 at sac
Old Nov 20, 2004 | 03:14 AM
JFG Kevin's Avatar
Default Re: AEM Tru-time cam gears (2k.civic.si)
that's just onces you went up there...i heard that someone's car blow up cause of aem cam gears...now i'm kinda scared to put on my cam gears...dont wanna be loosin a motor.
Old Nov 20, 2004 | 09:19 AM
V8SHME8's Avatar
Then buy different cam gears, there are plenty in the same price range or cheaper. I have these and they do not slip.
http://www.overboost.com/obs/p...Gears
Old Nov 20, 2004 | 07:07 PM
kommon_sense's Avatar
Default Re: AEM Tru-time cam gears (V8SHME8)
AEM now makes gears with 5 bolts...
Old Nov 21, 2004 | 02:32 AM
b19coupe's Avatar
I have been running the old school AEM three bolt cam gears for about 4 years, and they have not slipped. Many of these horror stories about various products come from people who have made installation errors-i.e. did not torque the cam gear bolts correctly in the case of cam gears.
Old Nov 21, 2004 | 10:12 PM
Supahr_Ed's Avatar
yea, it really depends on the installation and quality...i run old JG's and never had a problem. One friend is doing good with his AEM but my other friends AEM slipped. While on the dyno, my friend notice that one bolt was starting to strip, and since his cam gear only has 3 bolts, the 2 1/2 bolts isnt tight enough to keep it from slipping.
Old Nov 21, 2004 | 11:21 PM
JFG Kevin's Avatar
Default Re: (Supah_Eg6)
o ic...i would buy other cam gears but i aready have these ones in the garage...so it's kinda too late...i hope everything will work out ok for me...thx for the replies.
Old Nov 22, 2004 | 12:26 AM
ceLtic's Avatar
N/A wh0re!
they never slipped on my sohc zc vtec. and i beat on it constantly.
and the motor is now in my friends eg 4 door, and the cam gear has not slipped.
mind you it was a 3 bolt too. so far from me and my friend.
Old Nov 22, 2004 | 12:28 AM
ceLtic's Avatar
N/A wh0re!
Default Re: AEM Tru-time cam gears (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">I have been running the old school AEM three bolt cam gears for about 4 years, and they have not slipped. Many of these horror stories about various products come from people who have made installation errors-i.e. did not torque the cam gear bolts correctly in the case of cam gears.</TD></TR></TABLE>
^the horror stories come from people who didnt install them properly!
Old Nov 22, 2004 | 12:30 AM
H.A.R.T B18C1EG6's Avatar
Default Re: AEM Tru-time cam gears (ceLtic)
I havent heard anything bad about these cam gears.... well.... good luck anyways
Old Nov 24, 2004 | 12:35 AM
JFG Kevin's Avatar
Default Re: AEM Tru-time cam gears (H.A.R.T B18C1EG6)
how much is the bolts pose to be tq down?
Old Nov 24, 2004 | 01:28 AM
ATS*Mark's Avatar
OG triple OG
i was going to ask that too as the instructions that came with my SRR never stated the tq specs.
Old Nov 24, 2004 | 02:27 AM
JDogg's Avatar
Default Re: AEM Tru-time cam gears (Hella_JDM is back!)
aem gears come with torque specs... follow them and you wont have any problems.
Old Nov 24, 2004 | 05:55 AM
b19coupe's Avatar
Default Re: AEM Tru-time cam gears (JDogg)
Torque on my AEM gears is 19 ft-lbs.
Old Nov 25, 2004 | 01:09 AM
JFG Kevin's Avatar
this is on aem three bolt cam gears?
Old Nov 25, 2004 | 05:53 AM
b19coupe's Avatar
Yes.
Old Nov 25, 2004 | 08:25 AM
LSVTEC 91 Civic's Avatar
Banned
I have no problem with my 3 bolt gears.
Old Dec 7, 2004 | 06:52 PM
Supahr_Ed's Avatar
this is funny, as i said earlier in the tread, one of my friend has no slippage on his AEM cam gear...but he recently took them off to install new cams and finds out that the teeth on both cam gears are ALL TORN up. ironicly, THERE STILL NO SLIPPAGE!!! LOL
I going to see if we can get a new set or a refund for them...but they are over 3 years old. I will post pics soon if people want to see them...
Old Dec 7, 2004 | 09:52 PM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supah_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">...but he recently took them off to install new cams and finds out that the teeth on both cam gears are ALL TORN up. ...</TD></TR></TABLE>
from what i have seen thats not uncommon for any aftermarket cam gear...
Old Dec 8, 2004 | 06:18 PM
Default Re: (JDogg)
4 years of running aem cam gears with 3 bolts and to this day...3 motors later...they still look new and work perfect
Old Dec 8, 2004 | 08:30 PM
DxTrix's Avatar
Default Re: (2k.civic.si)
The AEM race car uses the cam gears so I am sure they dont slip.
HondaBoy954
Dec 14, 2007 04:38 AM
digital sol
May 2, 2006 04:11 PM
smkngsr
Apr 11, 2002 04:33 AM
b18c-93
Apr 4, 2002 05:10 PM
b18c-93
Mar 21, 2002 06:06 PM
