need help on wiring h22 with h23 block into 92 cx
dammmm man ive read all the forums and havent found the right one.... found little here and little there but not all of then... can anyone help out with my hybrid wiring? if you guys can post pic that would be great... i got everything set but the wiring
1. motor mounts
2. axles enjo stage 2
3. ecu p13
4. vtec head with cams
5. h22 crank gear
6. h22 timing belt
7. water pump
Modified by xkpxkingx_001 at 10:41 PM 11/19/2004
Modified by xkpxkingx_001 at 10:42 PM 11/19/2004
1. motor mounts
3. ecu p13
5. h22 crank gear
6. h22 timing belt
7. water pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkpxkingx_001 »</TD></TR><TR><TD CLASS="quote">
1. motor mounts
Quick question....are you going with enjo mounts? Im assuming this only because your using enjo axles. I heard some horror sotries about those mounts being crap.
Well the wiring is very simple. most plugs off your civic harness will work on prelude sensors. You have to change the civic injecotr plugs ans use the prelude ones. Also lengthen the alternator wire from civic harness and swap prelude alternator plugs onto in. There are a few others but thats just what i remember off hand.
1. motor mounts
slo_hatch
Mar 31, 2008 04:27 PM
