FS: drag turbo kit upgraded B-series integra or civic
Old Nov 19, 2004 | 07:35 PM
Rob!'s Avatar
Default FS: drag turbo kit upgraded B-series integra or civic
hey guys, i have a turbo kit for sale from my integra. its a drag kit with a few upgrades. everything has approx. 4-6k miles on it. IT COMES WITH EVERRYTHING NEEDED TO BOOST YOUR CAR. this turbo kit is also made so you can KEEP YOUR A/C and powersteering. and you do not have to cut your block for it to fit.
turbonetics T3t4b ball bearing turbo - ZERO shaft play
stainless intercooler piping
walbro intank 255 fuel pump
greddy front mount intercooler polished endcaps center painted black
Drag log manifold
2.5inch downpipe with o2 bung
Tial 35mm wastegate with dumptube routed to underneath car. (4lb spring)
Blitz sequential blow off valve
oil feed line
oil return line with lava proof coating where it goes around the down pipe
BOOST guage
all fittings for oil lines
all silicone hoses
all hose clamps
tapped oil pan with no leaks
FMU
missing link
missing link screws
as of now this is only pics i have. one intercooler shot and a distant engine bay shot.
i think thats everything but if there is something im missing PM me or email me because im sure i have it i just probably forgot to add it.
PRICE: 2300
Modified by EKsnatchback at 5:24 PM 11/28/2004
Modified by EKsnatchback at 7:16 PM 11/29/2004
Old Nov 20, 2004 | 08:37 AM
Rob!'s Avatar
Default Re: FS: drag turbo kit upgraded B-series integra or civic (EKsnatchback)
up
Old Nov 20, 2004 | 02:32 PM
Rob!'s Avatar
TTT
Old Nov 21, 2004 | 08:51 AM
Rob!'s Avatar
all pm's replyd...up
Old Nov 21, 2004 | 01:05 PM
JDMs1eeper's Avatar
Bump, thats a decent price
Old Nov 21, 2004 | 01:35 PM
Rob!'s Avatar
Default Re: FS: drag turbo kit upgraded B-series integra or civic (JDM S1eeper)
replied to all pm's keep them comin. thanks for the bump
Old Nov 22, 2004 | 10:15 AM
Rob!'s Avatar
up
Old Nov 23, 2004 | 08:43 AM
Rob!'s Avatar
up.
Old Nov 25, 2004 | 07:44 AM
Rob!'s Avatar
turkey bump
Old Nov 27, 2004 | 12:18 PM
Rob!'s Avatar
up
Old Nov 29, 2004 | 09:40 AM
Rob!'s Avatar
up
Old Nov 30, 2004 | 10:11 AM
Rob!'s Avatar
pm's replyed
Old Nov 30, 2004 | 10:35 AM
Eskay@JDMCircle.com's Avatar
bump for a nutty color
Old Nov 30, 2004 | 02:45 PM
Rob!'s Avatar
Default Re: (skt)
replyd to all PMs
Old Dec 1, 2004 | 03:52 PM
Rob!'s Avatar
Default Re: (EKsnatchback)
up
Old Dec 3, 2004 | 05:36 PM
tegsallgood's Avatar
what motor did u have
Old Dec 3, 2004 | 07:44 PM
Rob!'s Avatar
Default Re: (tegsallgood)
b18b
Old Dec 5, 2004 | 12:22 AM
SHystrdyGSRtdy's Avatar
how much power does this kit make? no larger injectors needed?
Old Dec 5, 2004 | 08:05 AM
Rob!'s Avatar
Default Re: (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">how much power does this kit make? no larger injectors needed?</TD></TR></TABLE>
on a gsr on 11 psi my friend made 318whp. if you plan to run high boost then your going to need injectors. if you go up to only 7-8 the stock injectors are fine. im only on 4 lbs of boost.
Old Dec 5, 2004 | 06:29 PM
herbalist's Avatar
could i put this kit on my 92 ls with a b18a?
Old Dec 5, 2004 | 07:36 PM
alloysr16s's Avatar
did u keep stock redline ? curious
Old Dec 5, 2004 | 08:26 PM
AXZ NYC's Avatar
where in jersey are you located? i live in NYC... so i would be able to see it and possibly pick it up...~
Old Dec 5, 2004 | 09:45 PM
blaster834's Avatar
Such a bad *** deal!! Bump
Old Dec 6, 2004 | 12:32 AM
cueballsi's Avatar
Default Re: FS: drag turbo kit upgraded B-series integra or civic (blaster834)
any ral pics of the engine bay and turbo parst?? what trim is the trubo ?
Old Dec 6, 2004 | 05:35 AM
Rob!'s Avatar
Default Re: FS: drag turbo kit upgraded B-series integra or civic (cueballsi)
yes this kit will work on a 92 ls with b18a, yes i kept stock redline, im located in central jersey, right now i dont have any engine bay pics because i havnt had the kit on for too long. i beleive the turbo is a .48 trim. its perfect for a daily driver, fast spool. and reaches full boost at around 3200 rpm's
7mile
Dec 25, 2005 09:41 AM
7mile
Nov 25, 2005 01:29 PM
corey's96GSR
Jul 4, 2004 03:43 PM
integra7
Dec 4, 2002 10:56 AM
gigantor
Oct 1, 2002 11:15 PM
