idling problem?
Old Nov 19, 2004 | 03:11 PM
^MikeG's Avatar
Default idling problem?
my car idle's fine when i turn it on and let it warm up in the morning...and when i get out of school. im not sure what its idling at cuz i dont have a tach.
...but if i start to get on it and rev it a little bit higher while im cruisin and then slow down and push the clutch in or go to neutral, the revs start to pulsate up and down. i have no idea what would could be causing it. if i turn the car off while its doing it and then start it up again it goes away.
...i also did an ecu check, and there is nothing...just a code 17 which is my vss that isnt hooked up...
the engine is a obd0 b18a1 in a 91 hatch.
Old Nov 20, 2004 | 05:44 AM
^MikeG's Avatar
no help....!??!?!
Old Nov 25, 2004 | 11:30 AM
Dohcvtec59's Avatar
Default Re: (^MikeG)
Here's some help I had the same exact problem. Idle surges. Check the Iacv on the back of your intake manifold I replaced mine hasn't came back since and also you might want to clean out your fast idle. It's right below your throttle body
Andr3w
21
Apr 13, 2009 06:15 AM
systemoverload
Oct 27, 2006 02:16 PM
2000civicsi
10
Oct 26, 2005 04:05 PM
xhatchracerx
29
Jul 17, 2003 09:33 AM
dangerous will
Dec 26, 2002 04:15 PM
