in need of some b-series clarification
Old Nov 19, 2004 | 02:00 PM
skittyscott's Avatar
Default in need of some b-series clarification
well, up until last week, i was looking forward to swapping in a built z6 motor until i realized that i could have more hp and torque out of a built b18 motor. it would cost me about the same amount to swap in either one because of the amount of machining and new parts i will be adding. althought i have read a lot, i guess i havent read enough and before i pick up the block im looking into, i have a few questions.
ive seen a lot of people talking about turboing an ls vtec motor. i thought the ls blocks had thin sleeves and wasnt good past 5500 rpms? also, what is the comp ratio on average lsvtec motors? like i said, i will be building this motor with a sleeved block, new pistons, and a lot of headwork so i need some advice on what comp pistons i should look into and whether to get flat top valves or dished valves.
also, i know the stroke is different between the ls motors and the b16/18c motors. does this difference make it any better for turboing or is it just a cheap block to start with?
thanx
scott
Old Nov 19, 2004 | 02:51 PM
LSvtec03's Avatar
Default Re: in need of some b-series clarification (skittyscott)
the ls sleeves arent an thinner than other bseries sleeves. the ls block is as strong as any other b block, it's just that the rod bolts are thinner and tend to break easier. new forged rods with arp bolts, or even just new arp rod bolts will help that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skittyscott &raquo;</TD></TR><TR><TD CLASS="quote">i guess i havent read enough</TD></TR></TABLE>
do a searchski, and you'll be all set.
Old Nov 20, 2004 | 08:51 AM
Default Re: in need of some b-series clarification (LSvtec03)
for the last two years ive been learning about d-series engines and i found so many sites dedicated to them, but i cant find many good ones on the b-series. does anybody have any good references?
thanx
scott
Old Nov 20, 2004 | 11:12 AM
dr_latino999's Avatar
Well, what do you need to know on the B-Series, or better yet, what is imperative that you need to know now a I have plenty of links on B-Series info.
Old Nov 20, 2004 | 12:02 PM
Default Re: in need of some b-series clarification (dr_latino999)
im planning on building an lsvtec turbo motor. i have been able to find a lot of sites on doing the lsvtec, but not as many dedicated to turboing the b motors, or better yet, lsvtec motors specifically.
thanx a lot
scott
Old Nov 20, 2004 | 12:23 PM
Here are the first four B-Series turbo articles that I can find in my bookmarks
http://www.beesandgoats.com/bo....html
http://www.c-speedracing.com/h...d.php
http://www.team-integra.net/se...D=325
http://www.team-integra.net/se...D=308
Old Nov 21, 2004 | 08:54 AM
Burlyirishdude's Avatar
here's a good one for teh XSI B series motor......it gave me a lot of info on my "not-so-little" engine.
http://integra.orcon.net.nz/
Good site.....But just for the XSI motor.
Demon_Dub
14
Feb 17, 2006 06:26 AM
EK9civicJDM
Mar 15, 2004 02:57 PM
sleepin91teg
Dec 18, 2003 03:20 PM
MUGENTYPER
Mar 17, 2003 05:53 PM
ekekek
Apr 1, 2002 12:26 PM
