Codes 19 and 21
Old Nov 19, 2004 | 01:21 PM
DemostheneZ's Avatar
Default Codes 19 and 21
19 Automatic transmission lockup control valv
21 VTEC spool solenoid valve
i'm a n00b but i just swapped my engine for another d16z6 and i'm gettin' these codes, anything i can do to fix it?
Old Nov 19, 2004 | 01:34 PM
chad's Avatar
Moderator
Default Re: Codes 19 and 21 (DemostheneZ)
search is your friend....
Old Nov 20, 2004 | 07:26 AM
Default Re: Codes 19 and 21 (chad)
FYI: search brings up nothing but threads that just say to search for it.
Old Nov 20, 2004 | 07:31 AM
CATCH DIS HATCH's Avatar
https://honda-tech.com/zerothread?id=682412
Old Nov 20, 2004 | 07:39 AM
2lua's Avatar
did you check the vtec wires? did you use the right ecu? manual or auto?
Old Nov 20, 2004 | 11:21 AM
Default Re: Codes 19 and 21 (2lua)
well my old engine took a dump, so i replaced the block, i didn't change the transmission at all, i kept the same head. same ecu. nothing else was changed, it's an auto tranny.
i did change the tranny fluid, so it's all brand new, could that have done anything?
Old Nov 20, 2004 | 11:23 AM
Default Re: Codes 19 and 21 (CATCH DIS HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CATCH DIS HATCH &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=682412 </TD></TR></TABLE>
yes as you can see, i cut and paste the error codes from there. and i can see what the code is, but it does not explain to me what i should really do. i need DIY help please.
r2d97
Mar 5, 2006 05:34 PM
JoeYu
Nov 16, 2004 04:03 PM
MidwestSi
Sep 9, 2004 02:44 PM
osuperjohno
May 14, 2004 09:59 AM
fastlude69
Jul 15, 2003 08:41 AM
