Distiguishing Stamp on CRX SI tranny!
Old Nov 19, 2004 | 12:31 PM
0ptimus prime's Avatar
Default Distiguishing Stamp on CRX SI tranny!
Ok, so my couson is purchasing a d16a6 tranny off of a CRX SI. I need to know if there's some sort of stamp that will distinguish it from HF and DX trannies. This way i can verify.
Any help appreciated, thanx!
Old Nov 19, 2004 | 01:03 PM
Default Re: Distiguishing Stamp on CRX SI tranny! (0ptimus Prime)
Old Nov 19, 2004 | 01:05 PM
CRX_Control's Avatar
search man! https://honda-tech.com/zerothread?id=924613
Old Nov 19, 2004 | 08:51 PM
jlicrx's Avatar
there is no real way to tell by looking at the outside of the transmission - you will read about looking at the numbers by the fill plug - PL3/A000, PL3/3000, PL3/9000, etc. and that will tell you - simply not true - those are casting numbers for the case and nothing more - PL3/A000 could be a DX, HF or Si (depending on year) and PL3/3000 could be DX or Si (depending on year) - ZC transmissions also say PL3/3000 & PL3/9000 - the PL3/letter & numbers have 35mm differential bearings - PL3/number & numbers have 40mm differential bearings - for the non-believers, i have a couple of transmissions that say PL3/9000 - they are 91 DX - if you believe they are Si, i will sell them to you for $250 each
keeblar
11
Jan 28, 2025 02:53 PM
BoostdRex
Aug 3, 2007 05:06 PM
CrxSi707
May 25, 2004 08:56 AM
ViperRedCRX
Nov 11, 2003 07:05 AM
allmotorEG-SI
Apr 1, 2002 03:51 AM
