PSi for es100s
Old Nov 19, 2004 | 12:00 PM
importdude2000's Avatar
Default PSi for es100s
205/45/16
right now its at 29
but i heard
- 5-8 of max psi...
es100 max are 50
so 40ish?
Old Nov 19, 2004 | 12:26 PM
.water's Avatar
Default Re: PSi for es100s (importdude2000)
ask tire store where u installed ....call them.
Old Nov 19, 2004 | 01:19 PM
Default Re: PSi for es100s (Bee8teenSee1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bee8teenSee1 &raquo;</TD></TR><TR><TD CLASS="quote">ask tire store where u installed ....call them.</TD></TR></TABLE>
ask myself?
my local sears said 29
but i been reading and seems the rule of thumb is 5-8 less than max pis
Old Nov 19, 2004 | 01:34 PM
Dan GSR's Avatar
I would run then between 35-40
but all 4 should be the same
Old Nov 19, 2004 | 01:40 PM
9000rpms's Avatar
Mine are at 35psi...195/50/15's...
Old Nov 19, 2004 | 01:50 PM
xprohx's Avatar
I think too much
Default Re: (9000rpms)
It doesn't say on the sidewall? I would go with 35 psi.
Old Nov 19, 2004 | 02:13 PM
LSvtec03's Avatar
Default Re: (xprohx)
the number on the sidewall is the max psi that the tire can handle, that doesn't mean that's what you should inflate them to.
Old Nov 19, 2004 | 02:20 PM
CBRF4i's Avatar
Inflate to 32-35 PSI. I work at a tire shop and thats what we put all tires at. Unless its like a Chevy 2500HD then its like 75PSI
Old Nov 19, 2004 | 02:46 PM
.water's Avatar
Default Re: PSi for es100s (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">I would run then between 35-40
but all 4 should be the same</TD></TR></TABLE>
i tihnk 35 is good..and i also think almost every car has same PSI..ext trucks,vans,bus
Old Nov 19, 2004 | 03:42 PM
AlphaKennyWun's Avatar
Ive tried everywhere between 30-44 psi and 38 psi works best for me on my 195/55/15s .
Old Nov 19, 2004 | 03:43 PM
JFG Kevin's Avatar
Default Re: PSi for es100s (Black Missile)
40-35 psi
Old Nov 19, 2004 | 07:37 PM
AWDxBOOST's Avatar
rule of thumb....street tires 30-35 for max comfort ride
colder weather u can go 35-40
i wouldnt go up past 40
Old Nov 19, 2004 | 09:13 PM
burnout289's Avatar
Default Re: PSi for es100s (itr_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bee8teenSee1 &raquo;</TD></TR><TR><TD CLASS="quote">i tihnk 35 is good..and i also think almost every car has same PSI..ext trucks,vans,bus</TD></TR></TABLE>
cars don't have PSI limits, tires do. and they are NOT all the same.
importdude:: the tire pressure depends on your driving. if you are just driving around town, you won't heat up the tires as much as if you were taking twisty roads as fast as you can without going off a cliff. since pressure is directly related to heat, the more heat = more pressure. I have 205/45-16 es100s and I go 32 front 35 rear or somewhere around there [gas station air pump gauges are crap]. if you put them at 40 or more, they can easily heat up and push you over the 50psi max.
and turning isn't all that heats up tires, driving fast in a straight line [90 on the freeway] will do it, too!
apologies if you know some of this already, but your post didn't specify, so there ya go.
Old Nov 19, 2004 | 10:16 PM
Default Re: PSi for es100s (burnout289)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout289 &raquo;</TD></TR><TR><TD CLASS="quote">
apologies if you know some of this already, but your post didn't specify, so there ya go.</TD></TR></TABLE>
woah thanks
just 20mins ago i went to a gas station LOL
put it at 35psi all corners
holy **** is it hella hard daily driving now...bumps are very very hard
i think imma lower it to 32ish on all corners
but this may sound dumb but how do i get it to 32 exaclty?
dam thoese gas station fillers suck
i might have to goto get a digital valvestem checker thiny
Old Nov 19, 2004 | 10:41 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">
having a psi gauge is the ONLY way pretty much, to get a specific psi. over at a SHELL gas station here where i live, they have a digital tire pressure gauge built in. you set your psi, (32,35,psi etc) and let it do its thing.
but i always double check with my digital psi reader just to make sure.
also make sure you air up your tires when they're warm. or after a day of driving. also i heard in winter, to fill them up a tad bit more then if you were to fill them up in the summer. cuz the tires mostly run colder then they do in the summer.
but thats just what i heard, not sure how accurate that is
Old Nov 19, 2004 | 11:13 PM
MikeSarr_GSR's Avatar
Default Re: PSi for es100s (..::91TEG-G2::..)
where do you run your tires at the strip. I have found that around 24-25 they get alittle waxy
Old Nov 20, 2004 | 08:30 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">
also make sure you air up your tires when they're warm. or after a day of driving. </TD></TR></TABLE>
you're actually supposed to air your tires when they're cold, before they get warm and the air pressure goes up.
Old Nov 20, 2004 | 08:39 AM
Dan GSR's Avatar
Default Re: PSi for es100s (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">
you're actually supposed to air your tires when they're cold, before they get warm and the air pressure goes up.</TD></TR></TABLE>
cecknight
Jul 19, 2007 07:10 AM
.water
Jan 28, 2005 02:32 PM
JimmyAtlantis
26
Jun 5, 2004 02:44 PM
k279
Feb 14, 2004 07:45 PM
2k1 GSR
Dec 14, 2003 11:50 AM
