dx motor work with std trannY?
Old Nov 19, 2004 | 07:45 AM
type Gendy's Avatar
Default dx motor work with std trannY?
Just bought a 91 std hatch. It needs new motor and axles. Will my crx dx motor / clutch bolt up to the std trannY?
I know the axles won't work.. which sucks
Old Nov 19, 2004 | 07:47 AM
dr_latino999's Avatar
Default Re: dx motor work with std trannY? (Evil Sick hatcheM)
The motor will bolt up and the axles will work. The hub side is different and since you are using the axles that came with the stock hubs you are fine.
Old Nov 19, 2004 | 01:57 PM
type Gendy's Avatar
Default Re: dx motor work with std trannY? (dr_latino999)
STD tranny will bolt to dx motor no problem? somebody said the splines were different and it woudlnt work. Both are '91
Old Nov 19, 2004 | 02:14 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Sick hatcheM &raquo;</TD></TR><TR><TD CLASS="quote">STD tranny will bolt to dx motor no problem? somebody said the splines were different and it woudlnt work. Both are '91</TD></TR></TABLE>
If both are '91 models, the transmission will bolt up directly to the engine using the existing clutch.
A different clutch is only needed when using an '88 transmission.
Old Nov 19, 2004 | 02:18 PM
type Gendy's Avatar
Default Re: dx motor work with std trannY? (Targa250R)
sweet thanks... 91 dx motor / clutch + std tranny = on the road again (er for the first time)
Old Nov 20, 2004 | 04:46 PM
type Gendy's Avatar
NEVER DONE this...but can u unbolt the tranny from motor, and pull just the motor? Leaving the tranny and axles still in the car?
If so, how much of a pita is this?
Old Nov 20, 2004 | 04:48 PM
More work then it needs to be if you try to leave transmission in.
Old Nov 21, 2004 | 09:55 AM
type Gendy's Avatar
So its easier to pull the hubs, pop the axles ...take the motor/ tranny out and swap tranny onto dx motor?
Old Nov 21, 2004 | 10:29 AM
IMO yes because if you just want to pull the motor out you will need to unbolt the axles from the hubs anyways and still pull the transmission away from the motor. That will be a PITA as you have two of the engine mounts to compete with so if you disconnect the tranny from those you might as well just leave it attached to the engine and pull it out with it. You can pull the tranny out and leave the engine in, but it is way more work to pull the engine out and leave the transmission in.
Tippyman
Mar 27, 2006 09:08 PM
hondaless
Jul 9, 2002 06:13 PM
89 CRX SI
13
Apr 22, 2002 09:21 PM
zcivicz
30
Apr 15, 2002 02:29 PM
