OBD2 with ok with vafc2....
Old Nov 19, 2004 | 01:36 AM
yeegsr's Avatar
Default OBD2 with ok with vafc2....
well exactly like topic says...
is OBD2 works well with vafc2 or vafc2 work well or OBD2....im talking about dyno tuned too....
Old Nov 19, 2004 | 05:45 AM
boosted k20's Avatar
Default Re: OBD2 with ok with vafc2.... (yeegsr)
yes it will work. i have an SAFC in my 97 OBDII LS. havent got a chance to dyno tune yet, but it will work good
Old Nov 19, 2004 | 09:21 AM
ShortBusTechnologies's Avatar
I have OBD2b ( CA edition) in my 01 GSR and I run a V-AFCII. Works fine. Only thing you have to worry about or rather shall I say do is, in the instructions it doesn't tell you to hook up the oil pressure signal to the #10 pin out. Took me a while to figure out. When I would hit VTEC, the check engine light would come on and then I couldn;t hit vtec after that (made a horrible sound). But its fixed. I set the VTEC at 5600 rpms on stock cams and stock motor and made a noticible difference in VTEC pull.
Old Nov 21, 2004 | 02:14 AM
yeegsr's Avatar
Default Re: OBD2 with ok with vafc2.... (ShortBusTechnologies)
how do you like the vafc 2 tuning...useful or not much contribution to gain
Old Nov 21, 2004 | 06:24 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">how do you like the vafc 2 tuning...useful or not much contribution to gain</TD></TR></TABLE>
If you're not going to be tuning it on a dyno, spend your money on a different upgrade.
ekcivicphx
Apr 24, 2004 06:34 PM
miksew
16
Nov 12, 2003 11:26 AM
GettaluvR
Apr 16, 2003 10:37 PM
integranator
Mar 3, 2003 08:37 PM
