ECU wiring for b16
OK i searched already with no straight answer. My problem is im wiring the vtec, knock, oil pres., and o2 into my ecu and im wondering what I do with the wires already in the spots im suppose to plug into. Also, I was able to get the wire out of the white plug, but i cant get them out on the two black plugs. is there a special way to do this? Oh and this is on a 90 civic Si.
Also, I have a wire in every hole. The only one that isn't there is a1. Everywhere I look everyone says there are 2 blanks that are used.
Modified by hybrid1990crx at 10:05 AM 11/19/2004
are you talkinga bout the ecu plugs not the sensor plugs on the motor?
you need like pins and stuff its kind of a bitch so just keep working at it, if you have to you can always cut the wire thats in there rather than un pin it, and then sauder your connection.
From: I told you to wait in the truck in Texas, United States
Make sure you remove the white "comb" looking things first..
I used a dental tool but it does take a while to get the hang of it...
If you can see the tab right at the end of the tool,that is what you are
fishing for..It is at a 45 degree angle and you will have to push it up parellel
with the pin/wire before it will release.
Good Luck..
red civic standard
Feb 25, 2002 05:13 PM
