Tein Users (swaping springs, front to rear)
Is this rumor true? can you swap the fronts with the rear?
This is on Tein RAs.
Reason for.. drag racing.. it would make the rear stiffer..
14f 10r are how it is now.
any thoughts?
any thoughts?
Give'em an email. I know for the old HA's you could only adjust spring rates +/- 2kg/mm from stock. So, for the fronts I could go from 8kg/mm to 10 or 6. The RA's are a higher up model, so maybe there adjustment range is greater.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTwinz »</TD></TR><TR><TD CLASS="quote">I run 18k up front and 14k rear. I'm running the type RS's and with a 22mm rear swaybar.</TD></TR></TABLE>
droool!
droool!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farside »</TD></TR><TR><TD CLASS="quote">Give'em an email. I know for the old HA's you could only adjust spring rates +/- 2kg/mm from stock. So, for the fronts I could go from 8kg/mm to 10 or 6. The RA's are a higher up model, so maybe there adjustment range is greater.</TD></TR></TABLE>
That is correct. They told me the same thing when I emailed them about stiffer rates for my HAs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eluder200K »</TD></TR><TR><TD CLASS="quote">More importantly, is the car up and running yet?
Sorry for the high-jack, back on topic...
i just have to pay for it now
</TD></TR></TABLE>i just have to pay for it now
That's crazy stiff. I've got the same shocks but swapped out the 14k front to 8k and kept the 10k rears.
Back to the topic, I could cofirm what members have said above, TEIN told me to send the front ones to have them revalved.
As long as the springs are of the same dimensions (height, ID, etc.), the springs will flip flop however you like.
I've got 4 different sets of Tein 70mm ID standard springs in 10, 12, 14, and 16 kg/mm, and I've swapped them around before as needed.
The tein website lists recommended and maximum spring rates you can use with each particular shock before it has to be revalved....and it is typically +/-2 kg/mm.
The springs will swap back and forth no problem.
I also have herd from tein that the shocks are only valve to handle a small increase, but I have a friend who bought stiffer front sprnigs and swapped the front to the back anyways.
He runs the dampening stiffer than before, but honestly it doesn't feel underdampened even at the road cource.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">me and my papaw jimmie rigged some ol alumeenum tabaccy cans between them thar coils so the coil contraption can't git shorter mm-hmm</TD></TR></TABLE>
Commanda did that?
Commanda did that?
urr hur hur, urr hur hur, boy ah tell yins what, that thar jetdopers guy gots a good humor abouts him
unkil trey was back in them woods out yonder by our new alumeenum roof porta john. come to think of it, i think he's back in them thar woods right now with out thurd cussin molly su cause i sure heer sum scremin, boy she musta shot his new gun witart askin mm-hmm
Dingity Dang Awkwafeeeenaw yo sho got sum craaazy in-laws....dat molly su is some pees o work, tekin treys gun...ho gave her leev to go otside in da fist place?????
Greg L
Sep 26, 2002 03:15 PM
