cranking noise from left side suspension....
Old Nov 18, 2004 | 07:40 PM
akteamster's Avatar
Default cranking noise from left side suspension....
i got a 96 hb stock except for tokico shocks and lowering springs.
recently i have noticed a cranking noise from my driver side front suspension area......usually only happens on hard corning sometimes even turns at normal speeds....any clue what it might b? i plan on taking it to the shop to get it checked out but i want to have an idea of what to tell teh mechanic, the noise only seems to be coming from driver side suspension area
Old Nov 18, 2004 | 07:45 PM
Ricey McRicerton's Avatar
Default Re: cranking noise from left side suspension.... (akteamster)
I've had the same junk happening to mine for months now. I can't figure it out and I've had the suspension apart multiple times.
Old Nov 18, 2004 | 07:48 PM
xerox445's Avatar
Default Re: cranking noise from left side suspension.... (Ricey McRicerton)
i know why my car does that sometime....
The bushing on the LCA that connects to the subframe rotated a bit and the bolt that goes through it actually pinches it. These bushings are the ones with the metal sleeves inside it. Makes a creaking noise evertime i get in becaues i had the LCA too low when i tightened it.
kharned08
Honda Civic (2001 - 2005)
Mar 20, 2008 08:37 PM
thtguybryan
Mar 7, 2008 03:26 AM
XtR-X
Apr 15, 2004 11:20 AM
EGO
29
Jun 9, 2003 09:10 PM
