disk brakes swap
Old Nov 18, 2004 | 07:08 PM
hondime9396's Avatar
Default disk brakes swap
i want to swap ex disks in to my 96 lx what does this job entitle?
Old Nov 19, 2004 | 05:10 AM
pyrojeff's Avatar
Default Re: disk brakes swap (hondime9396)
Just take the rear knuckles off an EX. This includes rotors, pads, and calipers, and to make things easier make sure it comes with the emergency brake line. All you need is circled in green.
Old Nov 19, 2004 | 07:43 AM
alphainspire's Avatar
Default Re: disk brakes swap (pyrojeff)
you can do it that way.
or just swap out the entire rear control arms from an EX Accord.
I just did this swap last weekend, and it took me and a friend about 3 hours to do.
Its not that difficult. All you have to do is unbolt the DX rear drum trailing arms and E-brake cable. Then bolt in the new EX trailing arm and run the new brake cable.
Also after you just have to bleed the brakes and thats it!
Breaking is not significantly different but I feel that my braking is much more linear.
Before with the drums the front brakes seemed like they did more braking. Now with the rear disc it seems as though a little has been taken off the fronts.
Old Nov 19, 2004 | 11:43 AM
pyrojeff's Avatar
Default Re: disk brakes swap (alphainspire)
Yeah, the rear brakes only provide about 35% of the stopping power. However, maintenance is much easier (for the most part). The shoes in the drums are a bitch to replace, but its still a hub-over-rotor setup
Old Nov 21, 2004 | 09:50 PM
well you guys have helped alot thanks can you check my power steering thread as well and mabye drop some advise?
Old Nov 22, 2004 | 02:08 PM
Nick H's Avatar
New User
Default Re: (hondime9396)
you should look into the legend 2 piston calliper upgrade if you really want upgraded braking for a decent price...
Old Nov 22, 2004 | 03:22 PM
-RedneckDave-'s Avatar
Working
Default Re: (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">you should look into the legend 2 piston calliper upgrade if you really want upgraded braking for a decent price...</TD></TR></TABLE>
Very true.
Old Nov 22, 2004 | 04:15 PM
ACC0RD22's Avatar
what does that entail? just new mounting brackets? and the calipers of course. . . or do you need new rotors as well
VegasEg8
Suspension & Brakes
17
Jan 3, 2014 08:29 AM
turboblack2door
Aug 9, 2008 01:45 PM
sony224422
Nov 26, 2005 07:04 PM
endlesswinterco
Oct 27, 2003 02:59 PM
kreush33
Oct 7, 2002 11:21 AM
