install AF autometer guage
Old Dec 27, 2001 | 07:11 PM
B18C-RnVA's Avatar
New User
Default install AF autometer guage
does anyone know how to install it, is it easy?? can someone list the step by step instructions on how to install it thanks
Old Dec 27, 2001 | 09:15 PM
speedymon's Avatar
Default Re: install AF autometer guage (B18C-RnVA)
If you look inside the engine bay (96 GSR don't know about other years/models)near the battery you'll see three harnesses (they are gray clip thingies that the wires go into) On the lowest one in between the two brown wires i think is the white wire. Connect it to that. I couldn't really tell the color of it since i looked at it at night. Man i must be bored. It's freezing outside and i go look to see the color of a wire. If you are still confused i'll install it for you, i got one myself. Hit me up on the email raydesouza@sprintpcs.com. I'm in Hampton, Va. Hope you ain't a ricer! Hahahaha JK.... Hope this helps. https://honda-tech.com/zerothread?id=105885
[Modified by speedymon, 5:23 AM 12/28/2001]
Old Dec 28, 2001 | 08:25 AM
speedymon's Avatar
Default Re: install AF autometer guage (speedymon)
called you man. Where you at? Hey lets trade ECUs!
Old Jan 1, 2002 | 08:57 PM
3rdGteg's Avatar
I thought the primary o2 sensor signal is a white wire with a red line through it that plugs into D7 of a '96 Integra ecu? I could've sworn it's a wht/red wire I read in the wiring diagram. Though where u are pointing to speedymon, it have no wht/red wire. (I'm tryin to install one of these A/F meter too, just wanted to make sure.)
Kylehugo
Apr 9, 2011 07:03 PM
doubleecho
Jul 16, 2007 09:30 AM
iperez
Jan 28, 2003 03:03 PM
