Hondata S200B Rev Setup
The FIVE Hondata Rev limits,
but I only see 4 that are changable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondata S200B User Guide »</TD></TR><TR><TD CLASS="quote">
1 flash = launch limiter rpm 1500 - 8000 rpm
2 flashes = cam change rpm 2000 - 8000 rpm
3 flashes = shift limiter rpm 5000 - 8000 rpm
4 flashes = shift light rpm 2000 - 9000 rpm
How The Fluff do I set Overall RPM Limit? I searched with no luck.
i thought it was 5 flashes for overall rpm, on my old stage 3 system. But mine was locked at 9200rpm i never needed to adjust it. i think this is correct. i just checked my s200 disc and it says nothing about the overall rpm, then i checked my stage 3 disc and it has overall rpm listed,(as 5 flashes). dont know if its a typo or what for the s200 system.
Modified by skunkwhat at 10:23 PM 11/19/2004
I am thinking that your overall RPM is what you set it on your ROM. Redline =9500. So you use the button to soft set the other 4 points. Maybe...
I haven't messed with mine since I cannot mount my 2-step switch yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonnyLee »</TD></TR><TR><TD CLASS="quote">you didnt mention the over all rev limiter on the list</TD></TR></TABLE>
What?
What?
The picture in the manual was not updated. There are only 4 points with the s200 to change. THe overall revlimiter is set in the ecu and burned onto the EEPROM.
ITRacer121
Oct 31, 2005 12:31 PM
