Bravo D15 Vtec swap in 87 CRXSi
I need the wiring information to complete a swap in a 87 CRX Si. Taking out stock and adding a Bravo D15 Vtec. kinda stuck with no wiring info so if any one can help I would Appreciate it.
I have the wiring already I just need to know how to hook up the Vtec wire up...The stock engine is non Vtec and the new is Vtec so all I need is a diagram for how to wire it up..Can you help Me??
Which ECU. Do a search.
If not changing ECu, you need to set up some sort of sithc linked to a tach, lots of posts on that.
If you have changed the ECu to a vtec ECU, then wire to the correct connection, pin out, once again lots of info on that.
Jay
Jay
