Bought an LS, now what?
Old Nov 18, 2004 | 05:59 PM
CompanyFlow's Avatar
Default Bought an LS, now what?
I recently bought an Integra LS, and want to tune it, but i dont know what to do, or what to expect. This is a long term project, but money will still be a big issue. Motor swaps and boost are definitely out of the question, thanks
Old Nov 18, 2004 | 06:04 PM
B18OnTop's Avatar
Default Re: Bought an LS, now what? (CompanyFlow)
https://honda-tech.com/zerothread?id=818820 <--- here i a great write up.
As for tuning Hondata ana Uberdata are some great thing to search.
how to search http://www.trials-shack.co.uk/posting.html for when you become a member.
-Aaron
Old Nov 18, 2004 | 06:05 PM
m0nk's Avatar
LSV!
slap on a gsr head, higher compression pistons (itr's will suffice), cams/sprockets/valve springs/retainers and u'r basically set...oh and before i forget, make sure to invest a 'bit on security (ie, connecting rods/arp head studs/stronger head gasket,etc)...and search, you'll find shitloads of info on this topic...happy tuning -alek
Old Nov 18, 2004 | 06:09 PM
HmgLauj69's Avatar
Default Re: Bought an LS, now what? (m0nk)
buy my parts!! check sig
Old Nov 18, 2004 | 06:26 PM
qcktegls's Avatar
Default Re: Bought an LS, now what? (HmgLauj69)
i have an ls. this is the steps im taking and have already taken are as follows.
start with
-i/h/e
-cam gears
-cam shafts
-valve spring and retainer upgrade
-intake manifold
-hondatas100
If you want to go real serious about all motor try a ls/vtec conversion or swap a gsr motor in the ls.
you do not have a need for a hondata or uberdata unless you have cams. there is no reason to do so other wise. you can do this step by step and work your way to a great car or you can save up for a while and slap in a turbo.
Old Nov 18, 2004 | 06:48 PM
Default Re: Bought an LS, now what? (B18OnTop)
Im counting LS-V as a motor swap because of its cost =\. What can i expect to run if I get the whole deal, as in I/H/E Cams and gears, valves springs and retainers, and such?
Old Nov 18, 2004 | 06:53 PM
realfastcrx's Avatar
be sure to search before you have any questions! if you don't you'll get flamed to hell
welcome to HT!
Old Nov 18, 2004 | 08:22 PM
qcktegls's Avatar
Default Re: Bought an LS, now what? (BS 22)
prlly around 180 hp. i dont know exactly and itll all depends on what other mods you have. good luck and keep us posted
Old Nov 18, 2004 | 09:14 PM
SlipAngleX's Avatar
I see you're in Cali, just save up some money and go w/the CARB certified Greddy kit (im hoping to do this )
Old Nov 18, 2004 | 09:41 PM
munki3b0i's Avatar
i suggest i/h/e and aem pulleys. that should keep you happy for awhile then do cams and cam gears.
Old Nov 20, 2004 | 10:51 AM
Default Re: Bought an LS, now what? (munki3b0i)
I was originally thinking of just waiting til i graduate (this year) and just selling this car and getting a GSR before i go to college, and i wouldnt mind driving the car stock. The car itself is fun to drive, but i want something a little better then stock for the time being.
Old Nov 20, 2004 | 11:06 AM
TeaAddict's Avatar
you are looking at...
i/h/e
intake/header/exhaust
if you want lower it?
that will run you close to $1000
dstappity
Sep 26, 2013 04:58 AM
pinoy_boi
18
Sep 4, 2012 06:43 PM
tna4me247
Jul 17, 2006 10:06 PM
mrxracing
Feb 11, 2004 08:28 AM
brando_001
Feb 2, 2004 07:08 PM
