Which LS Engine is non-OBD (or eisiest to swap into ED6 STD hatch)
Old Nov 18, 2004 | 05:44 PM
eumoria's Avatar
Default Which LS Engine is non-OBD (or eisiest to swap into ED6 STD hatch)
My plans were originally to do a turbo-ZC setup but after acquiring some mounts for next to nothing, my sights have turned to the beefier b18 LS non-vtec engine. Since they were produced here in the US it'll be even better for me to blow up with a turbo because I won't have to worry about ordering another one for Japan, only then need to make a local junkyard run.
I searched but was unable to find detailed old Integra LS information. I know that they are B18A1 B18A2(?) and B18B. Now from what I gathered the B18A1 would be prime for my car because it is(?) non-OBD? Is this swap basically (minus mounts, axles and linkage) the same complications as a ZC swap into a STD? Just the MPFI wiring? Something tells me there must be more. I know I'm going to need different coolant hoses. But what else?
The engine I want is from 90-93? The tranny is cable correct? Just some simple questions that everyone seems to know and don't mention in their posts.
Thanks for any help. non-vtec b18 guys!
Old Nov 18, 2004 | 05:59 PM
FIGARILA's Avatar
Default Re: Which LS Engine is non-OBD (eumoria)
92-93 had more power than the 90-91 (not sure about 92), 92-93 were obd-1 with a cable tranny. 90-91 b18a was rated the same horse power as a zc.
Old Nov 19, 2004 | 08:00 AM
dr_latino999's Avatar
Default Re: Which LS Engine is non-OBD (FIGARILA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FIGARILA &raquo;</TD></TR><TR><TD CLASS="quote">92-93 had more power than the 90-91 (not sure about 92), 92-93 were obd-1 with a cable tranny. 90-91 b18a was rated the same horse power as a zc.</TD></TR></TABLE>
Correct
90-91 B18A1 130HP@6000 121ft/lb@5000
92-93 B18A1 140hp@6300 121ft/lb@5200
DaViiS
May 2, 2016 08:19 PM
jdmed3
Oct 28, 2008 09:52 AM
hbombhondacrew
Jul 6, 2008 11:29 AM
JoshChoi
May 15, 2007 07:15 PM
jarvis199
Mar 1, 2005 02:36 PM
