is high 14's..sub 15's possible?
ok a while back a ran a 15.62 at 88 with a 2.33 60 had more in it
in a stripped 96 teg with SRI.
now i have removed another 100 pounds. removed a/c and p/s.
2 pulleys should free up power.
i also have a test pipe now
im thinking i can run at least a low 15 now. input??
Since when does less weight add hp? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SDT Project EF »</TD></TR><TR><TD CLASS="quote">maybe a low 15, I think for every 200lbs stripped its like 11hp</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">Since when does less weight add hp? </TD></TR></TABLE>
Power to weight ratio.
Yep, it is saying that since the engine has X amount less weight to have to pull it is equal to adding X amount of HP to the engine if you had never removed any weight. Its not litteraly saying because you removed weight your car actually gain HP.
im sorry but for 100lbs reduction = -.1 sec....yes point 1 sec..not 1 sec....lame math here...for removed p/s, a/c, test pipe, 2pulley = -.2 second
you will not pass get below 15sec unless you got good shifting...
