Need technical advice on V6 engine swap
Old Nov 18, 2004 | 04:34 PM
speedyacc's Avatar
Default Need technical advice on V6 engine swap
Hello everyone,
I was wondering if anyone has any information on which other V6 engines (possibly Acura engines), would fit into my 2000 Accord. I know there was some discussion on this earlier with regards to a 3.5 RL engine, but would anyone know if a TL 3.2 (type s maybe) engine would fit, without any modification. I may be dreaming, but I wanted to check anyway. I wanted to try something other than the Comptech supercharger available for the V6 to add to the performance, and without it, the engine seems to be topped out right from Honda, as far as performance. Any info would be great. Thanks!
Old Nov 18, 2004 | 05:44 PM
lowboost's Avatar
Default Re: Need technical advice on V6 engine swap (speedyacc)
what year is your accord, can't do anything without that. if it is a 6th generation, i know that you can put the 3.2TL motor into the accord without a problem, but it'll be pricey. if you already have the 6cyl all you need is the motor and ecu, everything else should work just fine including the tranny, but knowing how weak the accord trannies are, i'd just replace it anyway.
Old Nov 18, 2004 | 06:37 PM
Legendaryyaj's Avatar
If you are going to keep teh auto tranny than it shouldnt be a problem. There are a few ive seen with the cls 6spd but wiring is adn issue cuz the accord doesnt have a manual tranny ecu. I dont think the one from the CLS will work either.
Head over to http://www.v6p.net they have a lot of nice Av6's over there as well as a 3.5 RL swapped Accord.
jdmcivic2fast
Feb 19, 2012 03:29 AM
SkyLinER
Jul 3, 2003 07:14 AM
97V6ACCORD
Oct 25, 2002 09:10 AM
