It's getting so close i can taste it....
...my dashboard, that is.
calipers are powdercoated, rotor hats and caliper brackets are painted the same color.
can't wait till spring to try this out....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SDT Project EF »</TD></TR><TR><TD CLASS="quote">might i ask what is special about these brakes?</TD></TR></TABLE>
looks like the 11" brake upgrade
after having sat up pretty much all night doing the math (okay, i was 6 floors underground keeping an eye on some "things" for work and got bored and had to stay awake
) there's really nothing special.
they only are a 1" bigger rotor, 1/16" bigger master cylinder, and calipers with pistons larger than NSX. matter of fact, after doing a bunch more math, it became clear that in order for a stock DA caliper to have the same clamping force as the legend 2-piston caliper, the piston in the DA caliper would have to be just under twice its actual size.
so i guess there's really nothing special about them. sorry to have wasted your time, sir.
) there's really nothing special.they only are a 1" bigger rotor, 1/16" bigger master cylinder, and calipers with pistons larger than NSX. matter of fact, after doing a bunch more math, it became clear that in order for a stock DA caliper to have the same clamping force as the legend 2-piston caliper, the piston in the DA caliper would have to be just under twice its actual size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaskedDC4 »</TD></TR><TR><TD CLASS="quote">u should paint the caliper gold
nice upgrade
i say red. i wish i would of done mine red. but my uncle was talkin all this ish bout yellow.. so we did yellow. think ima change it tho.
how do you take that heat resistant paint off?
nice upgrade
</TD></TR></TABLE>i say red. i wish i would of done mine red. but my uncle was talkin all this ish bout yellow.. so we did yellow. think ima change it tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. »</TD></TR><TR><TD CLASS="quote">
how do you take that heat resistant paint off?</TD></TR></TABLE>
Aircraft Stripper
Nice Brakes... I gotta do a search and see where to get some Legend parts and mount them.
-Mike
Aircraft Stripper
-Mike
nope. DA ABS master. my car never had ABS (thank god--the DA system is really horrendous. more info on that is available at g2ic), so the master cylinder is only 15/16". the ABS mc from a DA is 1".
alphalanos
14
Sep 8, 2008 04:07 AM
