Thermostat location on a GSR? (searched)
I did a search for "thermostat" on here and couldn't find what I'm looking for. Does anyone have a picture of where the thermostat is on a GSR B18C1 motor is? I need to replace mine (it's stuck open) and would appreciate it if someone could help me out. (and yes, I am new to Hondas)
i just changed mines 10 mins ago on my 94 integra LS. its very easy to find, just find the big lower radiator hose, and follow the hose back until the hose comes to an end (above the starter). wherever the hose ends is where you will find the thermostat, just two skrews to remove the cover.. dont forget to let your engine cool first, that stuff will burn you!!
i just did mine last weekend. really easy.. follow this and you'll be fine: http://www.team-integra.net/se...D=222
yeah man.. just take your time. and when you're all done let it run with the rad cap off to get the air out of the system. i couldn't get that 18mm bolt off the block to drain the coolant there, so i just flushed the system with water a couple times then filled it up. remember to fill the overflow tank too..
CRXSi90
Apr 29, 2014 10:06 AM
Very much thanks indeed. I'll replace it this Sunday.
