obd1 in 90 civic speedometer
Old Nov 18, 2004 | 02:05 PM
toslowhatch's Avatar
Default obd1 in 90 civic speedometer
I was told when i go to obd1 for my ls vetc a sensor goes where the speedo goes. If so how do i get the speedo to work?
Old Nov 18, 2004 | 02:14 PM
Kataku2K3's Avatar
Default Re: obd1 in 90 civic speedometer (toslowhatch)
No, even if you convert to OBDI you still use your factory cable VSS. It's only if you swap your cluster for a non cable style unit ('94+ Teg cluster, etc.) that you'll need to run an electric VSS.
Old Nov 18, 2004 | 02:29 PM
Default Re: obd1 in 90 civic speedometer (Kataku2K3)
I don't know much about vtec but if the cable goes rigt into the tranny where will it get the signal for vtec ingagement? Thanks
Old Nov 18, 2004 | 02:35 PM
Kataku2K3's Avatar
With a mechanical VSS one end plugs into the VSS itself in the tranny and the other goes through the firewall and into the back of the cluster. The cluster converts the cables rotation into a pulsed signal which is then sent back down the ECU. It works the same way the newer electronic VSS's do, it just converts the signal at the cluster instead of in the VSS at the tranny. It's not something to even consider while doing the swap besides making sure the cable is plugged into the VSS and the VSS is bolted to the tranny.
RACEPAK
Nov 9, 2023 07:24 AM
boyee1
10
Dec 15, 2007 10:07 AM
SiMateoAko
May 13, 2006 12:32 PM
crxtreme27
Jan 19, 2005 05:48 PM
wickedEFguy
Dec 16, 2002 03:51 PM
