rear sway bar
Old Nov 18, 2004 | 01:07 PM
biggs2.3's Avatar
Default rear sway bar
ok so i am looking to buy a rear sway bar and lower tie down bar. does anyone have a good suggestion on which one to buy? i was looking fo a 24mm or 26mm size for the sway bar and i was also looking for a rear tie bar that had plates at the end for the sway bar to attach to. thanks in advance for any help.
Old Nov 19, 2004 | 09:07 AM
biggs2.3's Avatar
Default Re: rear sway bar (biggs2.2)
noone know>?
Old Nov 22, 2004 | 07:15 AM
uncle_el's Avatar
suspension techniques
intrax
progress
i guess, depending on the year and trim of your accord, you might be able to do a comptech sway bar made for a cl/tl.
a sway bar/anti-sway bar is much wider than a rear lower tie bar. they do not mount to each other.
Old Nov 22, 2004 | 01:48 PM
pyrojeff's Avatar
Default Re: rear sway bar (uncle_el)
The rear lower tie bar is pointless. There is already a metal bar attaching at the same places where the tie bar would go.
Old Nov 22, 2004 | 01:56 PM
Nick H's Avatar
New User
Default Re: rear sway bar (pyrojeff)
the suspension techniquest rear sway bar is probably the best sway bar for the accord in my oppinion...as far as the lower tie bar goes, as mentioned earlier, there is a metal beam attaching to the chassis already there...an upper strut bar for the rear is the only tie bar that would really help...
Old Nov 22, 2004 | 06:55 PM
iam7head's Avatar
Default Re: rear sway bar (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">the suspension techniquest rear sway bar is probably the best sway bar for the accord in my oppinion...as far as the lower tie bar goes, as mentioned earlier, there is a metal beam attaching to the chassis already there...an upper strut bar for the rear is the only tie bar that would really help...</TD></TR></TABLE>
ST gets my vote also
Tunerguy1989
Apr 30, 2009 11:25 AM
toguemaster
Apr 25, 2006 04:33 PM
^Sammy]!.
Feb 7, 2004 08:15 AM
slocrxsi
Sep 5, 2003 02:03 PM
moridin2004
Jan 10, 2003 01:44 PM
