Integra radiator support install?
Does anyone know what spot welds need to be drilled out to remove radiator support on a dc2 integr? or has any one seen a walk though on doing a jdm conversion and removing the complete support. thanx
If I remember correctly, the weld spots are at the upper corners where the headlights would be, the lower corner spots, as well as a spot in the center vertical cross bar. I think you would be able to see the marks, if you look closely enough.
http://tech.wiredspeed.com/jdm_front.asp
here ya go. hth
edit: also, if you got the hid headlights, i have the wiring diagrams for them if you need.
here ya go. hth
Thanx but Im looking for the complete core support install does any one have Im having a problem getting the bottom loose I have the top all broke loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22AJSPEC »</TD></TR><TR><TD CLASS="quote">Thanx but Im looking for the complete core support install does any one have Im having a problem getting the bottom loose I have the top all broke loose.</TD></TR></TABLE>
umm, yeah, that's in that link i posted, dude.
