92 DA pre-swap 2000 dc motor
Old Nov 18, 2004 | 09:36 AM
imaginary17's Avatar
Default 92 DA pre-swap 2000 dc motor
I'm preparing to swap in a 2000 dc motor into my 92 DA. I'd like to make sure before i order the parts that they will fit. Since i won't be able to return them let me know if it necessary or not and also let me know what other parts should be replaced.
Heres the list of what i'll be replacing.
92 DA motor mounts. replacing (ALL) mounts.
Alternator
Radiator
Clutch
Old Nov 18, 2004 | 10:01 AM
JustinG60's Avatar
Default Re: 92 DA pre-swap 2000 dc motor (imaginary17)
LS or GS-R or..?
Old Nov 18, 2004 | 10:08 AM
MolecularIntegra's Avatar
So what, are we supposed to know what parts are bad on your car and motor? Replace whatever is worn out or broken...
Old Nov 18, 2004 | 10:30 AM
MR-MUGEN's Avatar
Default Re: 92 DA pre-swap 2000 dc motor (MolecularIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MolecularIntegra &raquo;</TD></TR><TR><TD CLASS="quote">So what, are we supposed to know what parts are bad on your car and motor? Replace whatever is worn out or broken...</TD></TR></TABLE>
that he said
Old Nov 18, 2004 | 11:42 AM
2000 LS motor.
Let me clarify... are all the 92 DA parts compatible with the 2000 LS motor, such as motor mounts, alternator.. etc.
Thanks for the replies
Old Nov 18, 2004 | 02:02 PM
Clean91GS's Avatar
si. it should bolt right up. is the distributor plug the same on obd-I and obd-II? i can't remember.
Old Nov 18, 2004 | 10:53 PM
Stripped Honda's Avatar
99-0104
Default Re: 92 DA pre-swap 2000 dc motor (Clean91GS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clean91GS &raquo;</TD></TR><TR><TD CLASS="quote">si. it should bolt right up. is the distributor plug the same on obd-I and obd-II? i can't remember.</TD></TR></TABLE> they are different ...
vteckilla7
Aug 8, 2004 02:39 PM
paidroe454
Jul 10, 2004 07:32 PM
gliaw
Nov 18, 2002 02:17 PM
