Fiberglassing a whole EX dash...removal???????
95 civic ex --- I have plans to fiberglass my entire dash piece (not the plastic pieces but the entire dash piece) b/c i saw a del sol dash being fiberglassed at my local shop. So how do i actually remove the whole dash??? i know i need to remove the clock and all the plastic inserts and then are there screws holding in the dash or does it use the infamous honda "clips" like most everything else. what do i do about the passenger air bag??? can i desengage it? a bit dangerous???? need help.....thanks guys
for starters. remove the ground wire off your battery. take off all the plastic panel pieces you can (vents, kick plates, etc). the dashboard is held on by like 15 or so screws that are found on the sides, underneath and behind things such as teh radio. the srs is screwed onto the dash and theres a clip u have to disconnect to take out the dash. hth
ratchetej1
Oct 31, 2017 06:51 PM
