Vacuum leaks/idle adjust screw. Check this out
Old Nov 18, 2004 | 09:11 AM
sugarloafpkwy's Avatar
Default Vacuum leaks/idle adjust screw. Check this out
A tech at Honda dealership said if you screw in the idle adjustment screw all the way the engine will die if there ar eno vacuum leaks. Can anyone verify?
Mine's all the way in.
Old Mar 11, 2006 | 12:45 PM
the.hamburglar's Avatar
Default Re: Vacuum leaks/idle adjust screw. Check this out (sugarloafpkwy)
id liek to know as well?????
Old Mar 12, 2006 | 07:56 AM
Default Re: Vacuum leaks/idle adjust screw. Check this out (the.hamburglar)
ttt
Old Mar 12, 2006 | 08:11 AM
hondachris1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sugarloafpkwy &raquo;</TD></TR><TR><TD CLASS="quote">A tech at Honda dealership said if you screw in the idle adjustment screw all the way the engine will die if there ar eno vacuum leaks. Can anyone verify?
</TD></TR></TABLE>Iwould like to no also but I would think screwing the idle screw all the way would make the car die anyways,cause doesnt screwing it in lower the idle?
Old Mar 12, 2006 | 08:33 AM
movingIIshadow's Avatar
Well it seems pretty logical that it would work that way, because the idle screw lets a stream of air in, the looser it is the more air, and the tighter it is less air. So vacuum leaks would be evident if its all the way in and it doesn't die, because if its all the way tightened no air should be getting in and the car would die.
Old Mar 12, 2006 | 09:14 AM
coneheadsracing's Avatar
Default Re: (movingIIshadow)
you'd have to follow the procedure though, just turning the screw won't do anything, or rather never did for me. However, if you have a vaccum leak into your intake manifold, your idle would be screwed anyways, and if its big enough, you'd just go right to redline.
Old Mar 12, 2006 | 10:07 AM
Default Re: (coneheadsracing)
so follow the procedure in the book where you unhook the map or something like that?
b20bFourDoorCivicLX
Honda CR-V & Element
Oct 10, 2013 06:35 PM
downshift3r
Sep 30, 2013 06:34 AM
audiophyle_247
Jul 22, 2008 07:02 PM
GSTDA9
Feb 7, 2008 03:59 PM
bOOsTiNSoHcVtEc
Apr 23, 2007 10:07 AM
