lsvtec in a HF
I have a 98 gsr head, b18a block,and a y1 tranny i was wondering what other parts are needed to put this set up in my car (a 90 crx hf). another issue i have is that i love to drive my cars hard could there be an issue later on with my bad driving habits? thanks in advance.
-Ryan
-Ryan
Dude you'll need the following for your swap:
Motor
Transmission
ECU
Shift Linkage
Wiring Harness
There maybe more for your specific swap, but there's a general list...
Motor
Transmission
ECU
Shift Linkage
Wiring Harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin_Bradley »</TD></TR><TR><TD CLASS="quote">Dude you'll need the following for your swap:
Motor
Transmission
ECU
Shift Linkage
Wiring Harness
There maybe more for your specific swap, but there's a general list...</TD></TR></TABLE>
for the setup i wanna run what kinda ecu should i get and will any B seires shift linkage due?
I also herd for the HF you need to change your hole suspension?
Motor
Transmission
ECU
Shift Linkage
Wiring Harness
i just did an hf swap.
You will need everything the dudes said above.....
and you'll need to go and get the entire Front end hub from a dx or SI.... I went with the Si....Better brakes to handle the weight.
And some new springs might not be bad.....
goodluck
goodluck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude »</TD></TR><TR><TD CLASS="quote">i just did an hf swap.
goodluck
thanks man
goodluck
thanks man
hubs and steering knuckles have to go. I found that out when i was doing motor shopping around the local shops i used si hubs and steering knuckles . Do you want
to stay obd0 or convert to obd1. Your going to need to get a hydro conversion kit from hasport if you want to keep the tranny. hope i helped. sorry if i missed anything.goodluck.
NotPhilTran
Oct 11, 2002 02:30 PM
