LS install
Old Nov 18, 2004 | 07:53 AM
spyz34's Avatar
Default LS install
Just lookin for maybe a write-up or insight as to how hard an install would be for a B18b into a 91 CRX si. I searched archived and the knowledge database, but no dice. All I need is some personal experiences maybe a few links. Me and a buddy will be doing this, so any help at all is greatly appreciated.
Thanks
Old Nov 18, 2004 | 09:25 AM
DaX's Avatar
DaX
Loved
Community Favorite
Pretty much the same jive as any other B-series swap. You'll need a proper wiring harness, mounts, ECU, B-series axles, and a cable tranny [or a hydro-cable conversion]. Make sure your swap comes with the shift linkage also.
Old Nov 18, 2004 | 10:35 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Pretty much the same jive as any other B-series swap. You'll need a proper wiring harness, mounts, ECU, B-series axles, and a cable tranny [or a hydro-cable conversion]. Make sure your swap comes with the shift linkage also.</TD></TR></TABLE>
Pretty much what he just said. Except i dont think youd be able to use the linkage from the b18b. I might be wrong but it didnt work for me. I used the HASport linkage. Or you can have the other linkage cut and welded to work...but i dont trust those cuz a friend of mine had his break while driving down the road . As far as wiring goes...its basically the same as any b16 swap that you read about...minus the VTEC wiring.
Old Nov 18, 2004 | 11:19 AM
spyz34's Avatar
Default Re: (sCeRaXn)
Thanks. I think my motor is supposed to be a hyrdo tranny though. I still havent bought one but am looking. The guy i bought it from said that this motor is supposed to use hydro. Alright well thanks for all the info
ProricanEF
May 18, 2009 02:41 PM
chuckieD
Oct 5, 2005 10:45 AM
97civic123
Aug 14, 2005 09:17 PM
2s10w4u
Jun 10, 2005 01:28 AM
hondaless
May 1, 2003 09:40 AM
