Frame Slider mod on a 2003-2004 r6?
Old Nov 18, 2004 | 07:16 AM
Bictorious's Avatar
Default Frame Slider mod on a 2003-2004 r6?
I want to get frame sliders but i heard you would have to drill a hole through the fairings to have the slider bolted on. Is this true or can i there any other way the slider can go somewhere else without drilling a hole? Pictures would be nice too
Old Nov 18, 2004 | 07:33 AM
EGlovr's Avatar
ever heard of http://www.r6messagenet.com ?
http://r6messagenet.com/forums...28025
oh, and here's some insight to you wanting "no-cut" sliders:
http://r6messagenet.com/forums...24397 & http://r6messagenet.com/forums...20953
there's a whole forum on diy's there too: http://r6messagenet.com/forums...?f=49
Old Nov 18, 2004 | 07:56 AM
dennis's Avatar
Default Re: Frame Slider mod on a 2003-2004 r6? (Bictorious)
Just a heads up on "no cut" sliders... Not sure how they look on the 2003+ R6's, but I had them on my 2000. They usually work by being on a standoff that moves them over a bit to avoid cutting.
I went down on my left side, and not only did it bend the slider, it pulled a couple threads out of the motor (not cool) - I was able to clean up the the threads, but I instantly through those in the garbage and got the "cut" kind.
Old Nov 18, 2004 | 12:52 PM
ngng's Avatar
Default Re: Frame Slider mod on a 2003-2004 r6? (dennis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis &raquo;</TD></TR><TR><TD CLASS="quote">Just a heads up on "no cut" sliders... Not sure how they look on the 2003+ R6's, but I had them on my 2000. They usually work by being on a standoff that moves them over a bit to avoid cutting.
I went down on my left side, and not only did it bend the slider, it pulled a couple threads out of the motor (not cool) - I was able to clean up the the threads, but I instantly through those in the garbage and got the "cut" kind.</TD></TR></TABLE>
DO NOT buy no-cut sliders! You know this
Why would you want to buy no-cut sliders anyways, it's not too hard to cut?
Old Nov 18, 2004 | 01:00 PM
.Ash's Avatar
no cut sliders are just trash. if you are afraid of drilling your fairings, buy a set that are already drilled or have a shop do it.
Old Nov 18, 2004 | 01:14 PM
ngng's Avatar
Default Re: (Ashish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ashish &raquo;</TD></TR><TR><TD CLASS="quote">no cut sliders are just trash. if you are afraid of drilling your fairings, buy a set that are already drilled or have a shop do it. </TD></TR></TABLE>
your fairings will look a hell of a lot worse rashed up vs a set of drilled sliders
Old Nov 18, 2004 | 01:36 PM
hybridreams's Avatar
Default Re: (ngng)
my no cuts for my 03 snapped right off in a 20-30 mph lowside
Old Nov 18, 2004 | 04:35 PM
Etylorcen's Avatar
Default Re: (hybridreams)
Dont be lazy, cut yer fairings. If you want frame sliders to work properly u'll cut em.
Old Nov 18, 2004 | 09:41 PM
CATCH DIS HATCH's Avatar
Default Re: (Etylorcen)
Try Sato racing , they have frame slider with no fairing cutting
Old Nov 18, 2004 | 11:36 PM
Bictorious's Avatar
Default Re: (CATCH DIS HATCH)
can someone give me some sites with great prices on the non-cheap sliders please?
Old Nov 19, 2004 | 04:56 AM
EGlovr's Avatar
what researching have you done for yourself?
intuitive
graves
vortex
here's a diy before you try anything stupid
Old Nov 19, 2004 | 08:35 AM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: (Bictorious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bictorious &raquo;</TD></TR><TR><TD CLASS="quote">can someone give me some sites with great prices on the non-cheap sliders please?</TD></TR></TABLE>
WTF?! Spend money on some good sliders. Cheap ones break off! Couple of my buddies' bolts broke.
Old Nov 19, 2004 | 09:27 AM
Muffler Bearing's Avatar
Default Re: (EGlovr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGlovr &raquo;</TD></TR><TR><TD CLASS="quote">
here's a diy before you try anything stupid</TD></TR></TABLE>
Awesome write up, best I have seen in most all of my research.
ImportHatch
Welding / Fabrication
1293
May 19, 2016 11:32 AM
JUNKIE DUCKY
Feb 18, 2009 11:50 AM
weaksauce.org
Apr 9, 2007 04:52 PM
RR98ITR
Jun 13, 2005 01:48 PM
