OBD 0 to OBD 1 conversion on 91 civic dx
i have a 91 hatch and i am doind mini me swap, im thinking p28 , but that is obd1, How do i go about converting it from obd 0 to obd 1? do i have to change all the plugs running from the ecu? is there an easier way to do this with out losing anything. im not looking for the fastest car i just want something to keep me moving
thanks
thanks
If you have an Si model, or a DX and have already converted to MPFI, you can get an OBD0-OBD1 conversion harness then just add the 3 wires you need for VTEC activation (solenoid, pressure switch, and pressure switch ground)
Or you can just use a PM6 (stock OBD0 Si) and run an auxillary VTEC switch or controller
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dblock91 »</TD></TR><TR><TD CLASS="quote">?</TD></TR></TABLE>
You own an EF buddy.
groundedcivic91
Jan 19, 2005 09:33 PM
