is it ok to run power and speaker wires for front doors near each other?
Old Dec 27, 2001 | 03:25 PM
Volcom's Avatar
Default is it ok to run power and speaker wires for front doors near each other?
Am i going to have any interface? Also, when i turn the car off or the stereo off, i get a small cracking sound coming from the speakers. What is causing this? Any help would be great
Old Dec 27, 2001 | 07:18 PM
THE_-_MAN's Avatar
Default Re: is it ok to run power and speaker wires for front doors near each other? (Alphanumeric)
you can run speaker wires with piwer wire, but you cannot run your rac (signal cables ) with the power wires or you will get engine noise(whine with motor)
hope this helps.
corey
Old Dec 28, 2001 | 04:08 AM
redblues's Avatar
New User
You shouldn't have any interference, but it's still advisable to separate everything. I've found the best way to run wires is power wire along the driver side, RCA's on the passenger side, and speakers through the center.
The cracking sound is the the capacitors in your amp discharging.
Old Dec 30, 2001 | 11:49 AM
Steve's Avatar
Man, I know you're not supposed to run speaker wire with power wire and signal cable.
But guess what? Every system I've put together has had the power and signal wire run down the same side right beside each other (mostly because I'm lazy) My current install even has both rear speaker wires run along side aswell, I have never had ANY problems with interference, static, distortion nothing. It sound incredible.
I guess I'm just lucky that way.. hehe
MrSnake
Aug 22, 2008 10:11 AM
Allurian
Audio / Security / Video
Aug 8, 2008 09:40 AM
crxaddikt
16
Oct 23, 2003 05:43 AM
Skitals
Feb 27, 2003 11:20 AM
92Hatcher
Dec 27, 2001 08:47 AM
