I need a NON cable drive speedometer for a CRX
Old Nov 17, 2004 | 10:15 PM
JohnnieChimpo's Avatar
Default I need a NON cable drive speedometer for a CRX
I need an electric drive speedo for a CRX/Civic. Is the only one available the one from the SIR?
Old Nov 18, 2004 | 07:59 AM
Default Re: I need a NON cable drive speedometer for a CRX (JohnnieChimpo)
This shouldn't be hard to answer.
Thanks
Old Nov 18, 2004 | 09:02 AM
hatchinprogress's Avatar
i believe all obd-1 and up cluster's are non cable (so '92 and up shoud be "electric")
Old Nov 18, 2004 | 09:05 AM
kid-honda's Avatar
Default Re: I need a NON cable drive speedometer for a CRX (hatchinprogress)
The JDM clusters are electric and the UK and us ones are cable.
Old Nov 18, 2004 | 09:14 AM
crx_88_si's Avatar
Default Re: I need a NON cable drive speedometer for a CRX (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">The JDM clusters are electric and the UK and us ones are cable.</TD></TR></TABLE>
JDM SiR is electric. the ZC crx in japan is cable.
Old Nov 18, 2004 | 09:55 AM
doublethink's Avatar
Default Re: I need a NON cable drive speedometer for a CRX (crx_88_si)
anything 92 and up is electric, im currently making a writeup for this 5 speed 98 EX cluster that im putting in today.
and james has a writeup on here for the 99 si cluster which is very detailed. its in the faq topic i believe.
otherwise, if you want a real EF piece, its gotta be JDM SIR, or swap your vsss, theres tons of people on here who would buy that electric one in less then 2 seconds.
your choice.
Old Nov 18, 2004 | 10:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">i believe all obd-1 and up cluster's are non cable (so '92 and up shoud be "electric")</TD></TR></TABLE> like i said
Old Nov 18, 2004 | 11:15 AM
90civichbsi's Avatar
so are you wanting to put in a jdm cluster? or does the motor you have in your car have a electric vss and you want to use a stock cluster?
if you have a b series, use any 94-00 integra vss, or a 99-00 si vss, if its d series, use any 92-95 sohc vss although the other integra and and 99-00 vss's should work.
i just know you cant use a 96-00 sohc civic one b/c the bolt is in a different spot.
if your jsut wanting to use the stock cluster, jsut take a stock 88-91 vss and put it in the vss hole and sell the electric one.
PayMecracka
Apr 10, 2011 07:59 AM
JapJunkie
13
Feb 1, 2007 02:30 PM
gsxr1k05
Sep 3, 2006 10:52 PM
virginia_dude
25
Feb 1, 2004 06:38 PM
