uberdata sucess lsvtec 227whp and 151 ft tq!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommy69 »</TD></TR><TR><TD CLASS="quote">What setup?
i ll post on link so i don t have to post over and over
</TD></TR></TABLE>i ll post on link so i don t have to post over and over
heres setup
head
b16 with head work
itr valve
supertech daul valve springs and retainers
itr lma
wicked intake manifold
wicked stage 2 camshaft
64mm throttle body
intake manifold and tb port match
skunk cam gears( set at I-2/E-2) didn t even have time to adjust!!!
block
b18a block
85mm bore/RS sleeved
wiseco pistons
crower rods
tranny
clucthmaster flywheel
4.7 fd jdm type r tranny
act hdpp w/ 6 puck
fuel
rc 370cc injectors
b&m regulator set to 38psi@idle
aem fuel rail
walbro 255lph pump
uberdata!!!
compression of motor is 12.8-1 or alittle higher maybe 13.0-1
first impression of the set up was like dam!!!
this is a full race setup
car barely idles and dies alot
sounded like a v8 with big cams
and yes the car did ping like hell at first!
but after 10 hrs of street tuneing it idle and drove like a stock civic.
head
b16 with head work
itr valve
itr lma
64mm throttle body
block
b18a block
wiseco pistons
crower rods
tranny
act hdpp w/ 6 puck
fuel
rc 370cc injectors
aem fuel rail
walbro 255lph pump
uberdata!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cylinder »</TD></TR><TR><TD CLASS="quote">b18a block
Theres the kicker.
Theres the kicker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cylinder »</TD></TR><TR><TD CLASS="quote">just 200whp is hard to make
look at that b20 vtec i tune
it baseline 161 and end at 170whp</TD></TR></TABLE>True, good work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siR cr-x »</TD></TR><TR><TD CLASS="quote">those are good numbers
</TD></TR></TABLE>thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDelSol! »</TD></TR><TR><TD CLASS="quote">12.8:1 Compression on 91 gas???
yes
</TD></TR></TABLE>yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDelSol! »</TD></TR><TR><TD CLASS="quote">12.8:1 Compression on 91 gas??? </TD></TR></TABLE>
yes </TD></TR></TABLE>
Well, if you've retarded the timing that much, imagine what you'll do on 106.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike817 »</TD></TR><TR><TD CLASS="quote">good work</TD></TR></TABLE>
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">
good work, congrats !!!
Greg</TD></TR></TABLE>
thanks
good work, congrats !!!Greg</TD></TR></TABLE>
thanks
timing is retarded on high vac because of pinging
(up to 12 degress on some areas)
but timing is 31 degrees on o vac and it shows no signs of pinging
but the dyno graph is choppy
i think higher octane will smooth out the graph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">nice chit man!
thanks
do u still have the gsx throttle bodys 4 sale?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">wheres the dyno sheet?</TD></TR></TABLE>
scbmx87
118
Apr 7, 2009 11:35 AM
LSVTEC408
Northern California (Sales)
31
Oct 24, 2007 12:03 PM
