GSR Leathers?
Old Nov 17, 2004 | 08:23 PM
eghatchomar's Avatar
Default GSR Leathers?
Well I want some gsr leathers in my crx but i figure why not just get my si seats done in black leather? That way they will bolt right in and I wont have to do any mods or just put three screws. Im just wondering has anyone done this? and how do they look? exactly the same? and how much was it to do it?
Old Nov 17, 2004 | 11:40 PM
Nerologic's Avatar
u can run em but u need to rig up some stuff, the 2 front mounts work, but the back 2 u need to make one side the hole a bit bigger, and on the other use a ton of washes or a nut or both, and then run a longer bolt ...
Old Nov 18, 2004 | 08:08 AM
Default Re: GSR Leathers? (crxomar)
Anybody else do anything like this?
Old Nov 18, 2004 | 08:18 AM
shivern's Avatar
Default Re: (Nerologic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic &raquo;</TD></TR><TR><TD CLASS="quote">u can run em but u need to rig up some stuff, the 2 front mounts work, but the back 2 u need to make one side the hole a bit bigger, and on the other use a ton of washes or a nut or both, and then run a longer bolt ...</TD></TR></TABLE>
i dont believe you answered his question., he was asking if anyone has had their Si seats reupholstered with leather, not if the gsr leathers will fit...
and ya i've seen someone that has had it done, the only thing that has gone wrong is the side supports (lumbar support??) started to sag after a couple months, but other than that they look pretty sweet
Old Nov 18, 2004 | 09:05 PM
Default Re: (shivern)
Does anyone have pics out there?
Old Nov 18, 2004 | 09:40 PM
B16 ED9's Avatar
Default Re: (crxomar)
I have seen a post on this, you may wanna run a S-E-A-R-C-H
Old Nov 18, 2004 | 10:35 PM
SwappedTURBOegg's Avatar
88's wont work in a 91 i found out the hard way.
Old Nov 21, 2004 | 12:46 AM
Default Re: (maybewhenimdead)
Bump
Old Nov 21, 2004 | 01:56 AM
kapoosh valve's Avatar
get the jdm leathers
koolaidTnR
Sep 23, 2011 09:28 AM
higgunscrx
Welding / Fabrication
May 1, 2007 08:57 PM
reed857
10
Jun 7, 2006 06:20 AM
Arsenal
Jan 9, 2006 06:43 PM
xkhalil333x
Dec 24, 2003 12:49 PM
