Cams questions
Old Nov 17, 2004 | 07:20 PM
aznsins88's Avatar
Default Cams questions
will my gsr beable to rev higher with some aftermarket cams? I have a 1994 integra gs-r.
Old Nov 18, 2004 | 08:33 AM
ek9jdm's Avatar
Default Re: Cams questions (aznsins88)
yes, but why would you want to rev higher on stock internals? just because you get aftermarket cams isn't about reving past stock redline. They make power throughout the powerband.
Old Nov 18, 2004 | 08:47 AM
qcktegls's Avatar
the gsr already has a great redline. there is no need to change it. but cams and a nice valve spring and retainer set will help you make a good amount of power
Old Nov 18, 2004 | 09:02 AM
gsr-2nr's Avatar
Default Re: Cams questions (qcktegls)
depending on how high u want to rev get complete itr drive train cams,springs,retainers and then u will be able to go to 8400
Old Nov 18, 2004 | 01:50 PM
Mr.Chow's Avatar
Default Re: Cams questions (gsr-2nr)
its all about tuning
Old Nov 18, 2004 | 02:20 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznsins88 &raquo;</TD></TR><TR><TD CLASS="quote">will my gsr beable to rev higher with some aftermarket cams? I have a 1994 integra gs-r.</TD></TR></TABLE>
I'm not sure if anyone really answered his question.
Putting in aftermarket cams will not raise the rev limit. Modifying the entire head, in fact, won't raise the rev limit either.
That's done with either an aftermarket ECU (whether piggyback or standalone) or a modified stock one. You must determine if you are even making power over your stock rev limit, and then you must make sure your head is capable of reving that high (making sure you have the necessary reinforcements, such as springs, retainers, etc).
Old Nov 18, 2004 | 03:13 PM
Quiks66's Avatar
Default Re: Cams questions (shamoo)
Don't forget the bottom end as well. Stock blocks will only last so long if they're revved to the sky. And to reinforce Shamoo...no, aftermarket cams will NOT raise your redline, but they most likely would make peak power higher in the RPM range.
MI4$DC5
Apr 22, 2006 06:37 PM
tegsallgood
Nov 11, 2004 11:00 PM
MrBui
Mar 24, 2004 02:51 PM
1.8T_EG
Aug 19, 2003 05:58 PM
1.8T_EG
14
Aug 19, 2003 04:20 AM
