FS and FT 2000 Accord Coupe, FMAX turbo and Tanbe Stainless Steal catback, OHIO
PLEASE if anyone has stock coupe exhaust or you want to trade with YOUR COUPE (COUPES ONLY) PLEASE Post or PM me. I'm in a bind whatever you can help me out with would be great. Thanks
You will have to drive to me, I have the shop, lift, air tools, full access in cleveland ohio.
Ok its all coming down to one last problem I NEED A STOCK EXHAUST. I don't have the original. I will buy it used from you , OR trade plus cash for a 6month old STAINLESS STEAL CAT BACK!
http://tanabe-usa.com/exhausts/medalionhyper.asp
Accord Coupe 4Cyl 98-02 pipe size is 60 tip size is 115 T4021Z retails for $620.00...In trade for your OEM ( $450.00) COUPE EXHAUST ONLY please do not ask if I'll trade for your 4door. It Doesn't fit, hangers and pipe different setup.
I also have my FMAX turbo kit upforsale
Asking $2500OBO OHIO
FMAX turbocharger kit
- T3/T4 Turbonetics Hybrid Turbocharger (rebuilt with garrett center housing NEW only 10k on turbo)
- High Carbon Cast-Steel Turbo Manifold
- 2.5 Mandrel-Bent Downpipe (just installed new flex pipe)
- 3D Map Additional Injector Controller (ERL MF2)
- Tail 35mm External Wastegate (6PSI spring)
- 440cc Lucas Fuel Injectors (2)
- Spearco Front-Mount Intercooler
- 2 Bar Map Sensor
- GReddy Type S Bypass Valve (BOV)
- HKS Air Filter
- Oil Feed line with T fitting
- Oil Pan with oil drain line fitting
- Autometer Phantom Boost Gauge VAC/Pressure
- Autometer Phantom Air/Fuel Ratio
- Autometer Phantom EGT gauge
if you want to hear Vids of my exhaust or the BOV, lol, Check out my site (im the admin for the honduh.com site. Hopefully I dont get into problems for linking my vids off my site here on this board.
http://www.honduh.com/showthre...=7179
You will get a faster reply if you post on this page or email pkessie@c4fc.org SERIOUS BUYERS ONLY 330-310-3628
- 2 Bar Map Sensor
- HKS Air Filter
