Question about a Mini-Me in a 88-91 CRX Si...
Old Nov 17, 2004 | 04:25 PM
BigPlansNoMoney's Avatar
Default Question about a Mini-Me in a 88-91 CRX Si...
If I were to put an Z6 head (OBD-1) on an A6 block in an 88-91 CRX Si (OBD-0), and used a P28 ECU (OBD-1), would I need an OBD-0 to OBD-1 conversion harness?
Old Nov 17, 2004 | 04:31 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
you dont necessarily have to purchase a conversion harness, but your distributor and oxygen sensor must match your ecu in terms of obd.
Old Nov 17, 2004 | 04:36 PM
Default Re: (mike_belben@yahoo.com)
So could I use an A6 O2 sensor and Distributor on a Z6 head?
Old Nov 17, 2004 | 08:56 PM
reread my first reply and think a little harder.
Old Nov 17, 2004 | 11:36 PM
Nerologic's Avatar
u dont need to run a harness, it all depends on the distro you use...
u can hack an A6 to fit on their (u can stay obd0 and rig something up for vtec activation), or u can do it right and run a P28 (convert to OBD1 and run the z6 distro and run the motor to its potential)...
so its actually ur choice, u just need to run the distro with the correct ecu, or else it wont work...
Ocnaj
14
Jun 30, 2008 06:11 AM
Hondamonster
May 31, 2007 11:07 AM
C_R_X_V_T_E_C
Feb 28, 2007 04:45 PM
lildxr
Jun 19, 2005 05:17 PM
