what's wrong with my car ????????????? won't run well help !!!!!!!!!!!!
have a lsvtec fully built but sometimes it stalls when i come off the belt way i have a p28 ecu here is the list of mods . i think i might be the ecu sometime the cel comes on but it goes out . btw i tried my stock auto ecu car won't start.
could it be the ecu i have p28 chipped 3 chips 2 threw cel on but the idle is rough. it sounds like it wants 2 turn off . if i give it gas it ok turned up fuel pressure same problems new engine has 401 miles of breaking 2 500 miles ne help car will die without warning @ idle today i was not even driving the car had it running @ it die full or 93 octance gas .
block
99b18b
ac blockguard
arp mainstuds
golden eagle blockgirdle
arp headstuds
ge oil adapter
acl bearings
itr oil pump
gsr gmb waterpump
balanced crank
shotpeened rods
p73aoo pistons
new oil pan gasket
flp baffled oil pan
obx pulleys
itr crank pulley
drivetrain
gsr tranny
ls 5th gear
itr lsd
act stge 3 6 puck ceramic
comp clutch 9.5 lb flywheel
flp clutch line
compression 11:9:1
head b16a2
rev valvetrain
rev flat valves
port matching on tb & manifold
blox hi lift cams
65 mm str tb
blox manifold
h22 vtec 290 injectors flowed/cleaned
190 fuel pump
new valve gasket
new headgasket
new orings
tuning
p28 with chipped all 3 programs run horribly skunk 2, j racing, allmotor
ge cam gears
block
99b18b
ac blockguard
arp mainstuds
arp headstuds
ge oil adapter
acl bearings
itr oil pump
gsr gmb waterpump
balanced crank
shotpeened rods
p73aoo pistons
new oil pan gasket
flp baffled oil pan
obx pulleys
itr crank pulley
drivetrain
gsr tranny
ls 5th gear
itr lsd
flp clutch line
compression 11:9:1
head b16a2
rev valvetrain
rev flat valves
blox hi lift cams
65 mm str tb
blox manifold
190 fuel pump
new valve gasket
new headgasket
new orings
tuning
ge cam gears
Try the hybrid forum. We don't have anwswers to your questions, because none of us have hybrid motors. Please post this where you can actually get help.
what were you thinking when you entered the ITR forum to ask this question... you dont have an ITR .. or even the motor... SO BEAT IT!
FUCKTARDS OWN THIS FORUM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto »</TD></TR><TR><TD CLASS="quote">it was not my suggest it was some 1 else 2 enter it here i don't give damn about an itr </TD></TR></TABLE>
haha...someone is fugging with j00...they knew very well what would happen if j00 posted here.
You might want to try the "hybrid," "All motor," or the "Tech" forum.
Also one question mark, and one exlamation point is plenty...
Who is this person? [rhetorically]
Because lately this is the same answer all of the OT posters list as their excuse for posting OT and non forum specific related crap.
Me - who is thinking there is some great conspiracy, especially after that tard last night.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto »</TD></TR><TR><TD CLASS="quote">its a forum ! its not english 101 . who gives a **** . if u want proper english go study it . </TD></TR></TABLE>
If you can't speak intelligently, you aren't going to get any help or any slack at all. Hell, the members who are in europe are some of the most coherent people in here, and even IF language is a barrier they TRY. You on the other hand....
Your just diggin the hole even deeper dood.....
....quit while your ahead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto »</TD></TR><TR><TD CLASS="quote">i know what you're u bastard . your reply made no sense wtf? </TD></TR></TABLE>
My reply made more sense than that abortion of an english language you just posted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto »</TD></TR><TR><TD CLASS="quote">i know what you're u bastard</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto »</TD></TR><TR><TD CLASS="quote">My own reply reply made no sense wtf? </TD></TR></TABLE>
Exactly
Exactly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto »</TD></TR><TR><TD CLASS="quote">your reply made no sense wtf? </TD></TR></TABLE>
Then I hope you understand mine, Good bye!
99lsvtecauto
Nov 22, 2004 02:37 PM
99lsvtecauto
Nov 18, 2004 07:21 AM
